Question about John Deere Tractor Side Screen 1050,1520,2020,2030
Why is my crank case oil running out check stick hole
  • 843 Answers
Most likely you have a stuck or clogged PVC valve, so the normal pressure in the crankcase has no other way to get out. Or you might have too much oil in it. Or you might have bad rings and the blow-by it too much to all get out through the PVC valve.
Posted on May 13, 2010
What would make a hole appear in my oil pan passenger side over the starter replaced heads placed new manifold gaskets and new fluids started up and fluids blew up thru the dip stick.
If oil come out of the dip stick that mean your compression goes in the crank case insted of the compression chamber look like bad head gasket sorry
Mar 25, 2015 | Cars & Trucks
Changing the gear oil ?
see this instruction. God bless you
    • 1
      Park the Honda Foreman on flat ground and leave the engine running for 5 minutes to allow the engine to warm up. Place the oil drain pan under the crank case drain plug. Turn the engine off.
    • 2
      Remove the drain plug from the under side of the crank case using the ratchet set. Allow the engine oil to drain into the oil pan. Replace the plug to the bottom of the crank case and tighten the plug using the ratchet set.
    • Sponsored Links
    • 3
      Remove the small screw from the side of the crank case using the Allen wrench. Remove the cap labeled "OIL" from the top of the crank case. Insert the funnel into the hole where the oil cap was.
    • 4
      Pour Honda 4-stroke engine oil into the funnel until the oil starts to come out of the hole where the small screw was on the side of the crank case. Once the oil starts to come out of the hole, stop pouring and replace the screw. Remove the funnel and replace the oil cap to the top of the crank case.
Read more: http://www.ehow.com/how_6512146_change-oil-honda-foreman.html#ixzz2ZPlA2Cu0
Jul 18, 2013 | 2004 Honda VT 750 Shadow Aero
Help please
There is a dip stick screwed into a tube on the side of the crank case or a screw plug directly into the crank near the bottom (normally coloured red) If it is a screw plug then unscrew and correct oil level is near top of thread Replace plug when finished. If it is a dip stick remove the dip stick--- wipe clean ---and replace screwing it all the way I. Remove again and check oil position on dip stick Should be on top mark or top hole if there are holes.
Apr 26, 2013 | Cell Phones
My lawn mower started smoking-whitish, looked like it came from the carb. It also made some shaky noises like something was loose. Then it quit running. A while later I started it again-it started fine,...
Recheck your oil level. The smoking routine you mentioned sounds like the crank case is being over-pressurized from too much oil. That results in the crank case breather dumping oil into the intake of the carb. Then you see all the white smoke and hear the engine making odd sounds because of the excess crank case presure. Just re-check the oil level. There are 2 lines on the dip stick. The oil level should NOT be above the upper line with the dip stick fitted in the run position.
If you still have the problem please respond with an engine model number. If it is a Briggs and Stratton engine the number will be on the air shroud near the spark plug wire. Honda and tecumseh the number will be not far from the lower end of oil tube or next to the dip stick on engines without an extended tube stamped on side of the engine base.
Let me know if you still need help after correcting the oil serviciing level. There is more that can be checked..... just need that engine number.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | Garden
How much oil what wt.
Most any kind of 4-cycle motor oil like 10W-30 will work in these motors. After draining the old oil replace the drain plug. There are two types of motor oil fill holes: 1. If you have a motor with the oil fill/check hole on the bottom of the motor and a small screw-in plug either with or without a small dip stick on it; with the motor level, fill the crank case with oil until it is up to the threads on the oil fill/check hole. 2. If you have a motor with a long dip stick that goes into a filler tube at the top of the motor, again with the motor level, put in about half a quart of oil and use the dip stick to check the oil level. If not full, add quarter quart amounts and check again until the oil is at the full mark on the dip stick. Do not overfill the crank case with oil. Most motors will take about one quart of oil but it varries so watch to see the oil level come up to the proper level.
Feb 03, 2011 | Porter Cable PorterCable DBSI325 3250 Watt...
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
How much gear lube do i put in the crank case of my 93 yz 250?
There is always a dip stick in the crank case to check the oil level. On the dip stick you will find two marks for Min and Max oil levels. The oil should never be more than the Max level and never below the Min level.
Mar 15, 2010 | 2003 Yamaha YZ 250
Gas in the oil
what engine are you talking about ?
sounds like the floats are stuck in the carb and have flooded the engine, strip and clean the carb (s) out, change the oil and then try to restart bike.
Jun 21, 2009 | 1982 Honda GL 1100 Innerstate Gold Wing
I need 2 know how much engine oil i need for my honda cr125.
If it doesn't have a dipstick or a sight glass window on the kick starter side you will find a srew / bolt on the case usually lower front right near the rear foot brake unsrew that then put your oil in the filler hole when oil comes out of the hole you took the screw/bolt out of you are full I have an 01 and thats the way it is or 650cm of oil
Apr 21, 2009 | 2002 Honda CR 125 R
Oil and gas blowing out dip stick tube
sounds like your fuel pump is leaking fuel into your crank case meaning your oil pan
Apr 04, 2009 | 1985 Honda Accord
John Deere Tractor Side Screen 1050,1520,2020,2030 Logo
181 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
