Question about Xenarc 700TS Touch Screen 7" TFT LCD Monitor
Curser moves randomly around screen
My curser randomly moves around the screen and revers to centre if I rub the screen it behaves normally for a few minutes then does the same again.
Rattling in engine bay
check your belts and the bolts around that area, sounds like loose bolts causing something to move and rub
Aug 05, 2013 | Vehicle Parts & Accessories
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Typing moves?
It could be that your hands are brushing against your trackpad.
Jun 16, 2009 | Apple PowerBook G4 Mac Notebook
Logitech Marble Mouse became erratic then stopped
Nope have to throw it away and buy another. I've had this same problem every 3-4 months: works fine then it disappears from device manager then it works again at random. I end up replacing it after my curser stops moving for minutes at a time. After a few months the replacement does the same thing. My 5th replacement will be Kensington, Logitech apparently sucks
Apr 11, 2009 | Logitech Marble Mouse Trackball
Cursor jumps around the screen randomly when I type
well..that can happen when the palm of your hand touches the touchpad, as you are typing..happens to me all the time. try it with your hands a bit more over the top fo the laptop..
Oct 15, 2008 | Computers & Internet
How can I stop my curser from jumping around whilst typing ?
Hello
Most probably because your 'Touch Pad Mouse' is touched by your palm (hand or something) while you are typing. Avoid contact with the mouse touch pad while typing.
Option 2:
If you have a centre moveable mouse on your laptop, start using it and disable the 'Touch pad mouse'
Best of luck!
Jul 23, 2008 | Acer Aspire 5100 Notebook
Curser lockup
clean the lens if u have a laser mouse
Nov 30, 2007 | Logitech Wheel Mouse Optical
Cursor lockup
updates the mouse drivers once and check out ...
Xenarc 700TS Touch Screen 7" TFT LCD Monitor Logo
23 people viewed this question
Top Xenarc Computers & Internet Experts
David Payne
David Payne
Are you a Xenarc Computer and Internet Expert? Answer questions, earn points and help others
