Question about Microwave Ovens
I have a Whirlpool velos model GH7208XR Microwave oven. Can someone please tell me what the error code f3.h1 is and how I can fix it? I think it has something to do with a humidity sensor...Thanks!
  • Microwave Ovens Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
There should be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
Does the code appear all the time, only when you cook using a certain mode, or any time you cook, etc.?
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
I have to slam the door very hard for it to close correctly what would cause this problem?
Incorrectly adjusted door catch. They have movement on them to allow a tight seal due to the microwave capability.
I just found the specs and instructions on it.
Whirlpool Gold 2 0 cu ft Velos SpeedCook Oven
Mar 09, 2016 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool Velos GH7208XR Convection works fine but microwave says door open and will not work on microwave. could it be door latch but then why does convection work?
I'd check the primary and secondary door switches for proper operation. Could be a failed switch, or adjustment issue on the switch assembly or door latching mechanism.
You also might have a failed thermal protector on the magnetron.
Feb 16, 2016 | Whirlpool Microwave Ovens
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
I have a whirlpool magic 1200 and it doesn't drain. Can someone help please
First, check the lid switch, the lid was probably dropped and it broke the switch. Next, disconnect the drain hose and make sure it is not plugged up. You could have a sock or something stuck in the hose that would stop the water from draining. After you do that, check the belt on the pump and then the pump to see if it is working correctly
Feb 08, 2010 | Whirlpool GH7208XR Convection / Microwave...
My whirlpool microwave GH7208XR is displays and error saying F7 HVSMPS feedback
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 22, 2010 | Whirlpool GH7208XR Convection / Microwave...
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
Microwave Ovens Logo
276 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
