Question about Sony STR-DE595 5-Channel Amplifier
No audio Last week I was cleaning my stereo and I disconnet all the wiring audio to clean the back, after I finish by mistake I turn on and of the wired of the sound make contact and smoke came out. It turn on and off and after a second on is sign saying protector mode. It is true this system is not working no longer or I only have to replace the audio and how much will be the cost
  • Sony Master
  • 17,130 Answers
I am so sorry that this accident happened. Unfortunately it is very important that when doing any cleaning or otherwise the power must be discconnected. I am afraid you have got your output damaged and it will need replacement. Since the output speaker wire or so would have made contact with the ac, this had shorted off the output. There is nothing that can be done than to replace. Try to do this job only if familiar other wise find out the price of the output drive after confirming the damage. If your are lucky the fault could be minimum if the resistor smoked and disconnected the circuit. I hope you will be lucky this time. Good day
Posted on Jul 24, 2010
I deleted my winclean by accident
Try this. Go to Control Panel and click Programs (not uninstall) You should the see Turn Windows features on or off. Click that and see if the win cleaner is one of these features. If it is you can turn it back on again. If it's not then you will need to re-install the software from the disc or place you got it from.
Sep 24, 2014 | Computers & Internet
Power
USE PROPER GAGE WIRE CHECK ALL FUSES TO THE BATTERY,THE FUSE ON THE AMP,MAKE SURE YOUR CONNECTED TO ELECTRICALANNTENA POWER WIRE ON STEREO (ITS USUALLY BLUE WIRE OR OARNGE WIRE ON BACK OF STEREO)BE SURE YOU HAVE A GOOD CLEAN METAL TO METAL GROUND WIRE CONNECTED TO BODY CHASSIS///SOME NEW STEREOS HAVE DIFFERENT WIRES ON THEM FOR CONNECTING AN AMPLIFER BE SURE TO CONNECT TO THAT WIRE THE REMOTE AMP PWR WIRE
May 25, 2013 | Kicker 06ZX750.1 Car Audio Amplifier
Sound Issues with Stereo System
It is more than likely the audio output transistors have shorted out, test equipment will be needed to find out the extent of damage.
Sep 02, 2012 | Audio Players & Recorders
Water Damage/Power Protect...
Something has happened to it. Might be an IC fault. Seek assistance of any experienced service technician.
Jun 07, 2012 | Sony MHC-GS300AV CD Shelf System
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
When i turn up the volume the deck turns off then turns back on
What kind of car do you have the stereo in? It sound exactly like a bad ground wire. To trouble shoot this, simply find a good clean ground point to hook the black wire from the radio to. you can usualy find somewhere behind the dash that the factory has grounded things to. I asked what kind of car, because some fords, and nissans do not have a ground wire in the factory radio harness, even though the adtor harness you may have used will have one. Hope this helps.
Aug 17, 2009 | JVC AM FM CD DET FACE CAR STEREO
Led light turns red and the turns off but the amp
In Car Amplifiers have 3 main power wires:
Live +12v (Fused wire direct from the + side of the cars battery)
Ground (Direct to car earthing point (anywhere cleaned of paint for good connection)(I tend to use boot lock)
Remote (This wire should be connected with the switched live wire coming from the back of the stereo, this is Only live when the cars ignition is on)(there should be 2 power wires coming from the stereo usually red live +12v and yellow switched live, depending on the cars original wiring, try moving the remote wire from where you have it, to the other live wire
Hope this is of some help
Aaron
Aug 08, 2009 | Nitro BMW-482 Car Audio Amplifier
Display doesn't illuminate on flipdown faceplate
Has unit gotten very cold lately? If faceplate is removable, remove it and clean the brass terminals with a CLEAN pencil eraser, wiking sure to blow off any rubber "crumbs" when finished.
Mar 10, 2009 | Car Audio & Video
GEM SOUND PA-750 POWER AMP
Hello plumer,
Locate a small slide switch at the back panel of your amp.
3 terminal and if you've snapped one of the wire, you'll see where the wire goes. But if it is 2 wire and using a ribbon type, follow the arrangement of the wire. No harm to the amp if you make a mistake. if bridge, all power will be shifted ti the left channel.
Good luck,
Mar 23, 2008 | Audio Players & Recorders
??Confused and angry!
Try hooking an mp3 player or some other source into the amp (in place of your car stereo)while the car is running to test it. You may have damaged the output of the radio. If not report the results here.
Sep 12, 2007 | Jl Audio 250/1 Car Audio Amplifier
Sony STR-DE595 5-Channel Amplifier Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
