Question about Dell W4201C 42 in. Plasma HDTV
When i turn my tv on the screen stay dark an i get no picture.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to check the X and Y sustain buffer boards. When either of these boards goes bad then the common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged capacitors on these boards and replace whichever has gone bad. If still the issue is not resolved, then please check the power supply board. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 13, 2010
Top left and right corners are dark on my 55 inch seiki tv
The picture tube could be getting old.
Normally this effect can also be due to alignment with the magnetic meridian.
You can try to de-gaussing with a high voltage gun.
http://www.repairfaq.org/sam/crtfaq.htm
see section
CRT Age Resulting in Dark Picture
Aug 20, 2016 | Televison & Video
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
Feb 26, 2013 | Archos 70 Internet Tablet
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
RCA TV. No picture yet has sound.
I unplugged the tv and the cable box and pulled out the battery of controls for 12 hours. When I turn on again, the tv and cable box back to normal.
Jan 24, 2010 | RCA Televison & Video
Dark Screen and red and blue lines
Those lines tell me that you may have a leaky electrolytic capacitor in your vertical circuit.
Feb 10, 2008 | Mitsubishi VS-60607 TV
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
Dec 14, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Dell W4201C 42 in. Plasma HDTV Logo
330 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
gwix50
Level 1 Expert
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
