Question about Dishwashers
Hey guys, I am a dishwasher repair guy in barbados, the caribbean. I am having problems with a Hobart LX30H. the relay board is doing half the things right and the othrs not at all. I replaced it with a new one and the same results. At startup, the wash sump heater and wash motor are running, but the fill valve, drain valve and rinse booster are not running. Hence the startup operation is stalled. the funny thing is that the rinse booster and fill valve led's on the relay board light up at there correct operational times show these processes but the processes are not actually carried out.
  • Dishwashers Master
  • 3,247 Answers
Not sure what sort of problems (fault codes etc) you were having before you chose to go on the path of replacing the relay board.
It might help to know what fault codes you have been noticing.
One possibility is that the power supply is not giving enough current to operate the devices which you notice are not starting eg, sump heater, fill valve, drain valve. The LEDs coming on does not mean the devices have got the actual power. The relay might have actuated and that is what the LEDs convey.
You have to check incoming water temperature plus the water pressure as well.
I am assuming you have a proper user guide for this, if not see
http://www.askanowner.com/_upload/1_2/attachments/LX30H_1.pdf
Please post a comment to say if this is helping or not. Happy to try to help you fix this. I do not have access to a repair manual for this manual.
Posted on May 14, 2010
  • webmaster400 May 14, 2010
    I was looking to save some time by asking you guys yesterday, but I had no choice but to dive right in and do full diagnostics because they needed the washer for the weekend. It turned out that the incoming power for one set of relays was cut by a blown fuse but not for the other set of relays on the same board. Thanks anyway. Just got back from the client and the washer is up and running. By the way, the error codes don't help for some problems. Thanks any.
  • Sam May 14, 2010
    Thanks for your posting. Glad to know the problem was with the power supply as I had thought.
    Please do rate the solution provided by fixya.com as it helps to know what our customer think of the efforts taken by the consultants.
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
I have a hobart am12 dishwasher. It blew the breaker. My service guy "who isn't a hobart dealer" said motor was bad. So I took it to a motor repair shop to be rewind. The motor repair guy said that he only...
http://tdfoodequipment.com/images/am14-14c.pdf
This has the contact info for Hobart on it. Given the age of the unit though, you might be out of luck. It is possible that the motor was done correctly and the power issue is somewhere else. There could be an internal fuse or a power transformer that has failed/
Nov 04, 2013 | Hobart AM14-253 Free-standing Dishwasher
Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Feb 07, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx30h hobart dw. booster will not turn on. element good,hi-limit is good, changed temp probe, still no power to contactor
The booster heat control circuit is controlled by the relay board. Visually check for loose or burnt relay contacts...
You will see the booster LED light when it calls for heat. Some newer machines have a second high limit on the right hand side of the booster tank.
It may be your control board is configured for low temp with no booster. When you power up, the display should say LX30H. If not
Pull open the upper drawer, place a magnet over the door interlock switch.
CAUTION, 220 volt power is present. be carefull what you touch.
on control board, short J5-1 and J5-2, then power up. You are in factory setup. press select on the control board to see each option on the front panel., press up arrow on control board to step up through options for each step. when done, press the off button on front panel. remove short and start up normally. With the magnet in place, AND THE DOOR CLOSED, run the machine and observe the relay board status lights.
If you want to adjust the temp set points, with the machine off, press and hold the hidden key behind the front panel logo, and press select on the control board.. Or on power up, hold the wask key..Same to adjust options as above. Press off to exit.
Jul 04, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
UNDERCOUNTER DISHWASHER (HOBART)
Can you give me the model number thats on the data plate,it should be a lx18,lx30h,lxih.Im a hobart tech and repair these units alot,let me know.
Sep 03, 2008 | Dishwashers
LX30H Hobart torsion bar adjustment
im a service tech for hobart,there are no adjustments,the torsion bar is broken.the parts arent expensive but installing them are tricky.
Dec 06, 2007 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
