Question about Dishwashers
GE dish washer model gsd2600go2bb will not fill with water or just a little water,its not getting the water its suposed to.
    President:
  • 949 Answers
This is due to one of two issues, either the water from the house is restricted or the valve in the machine needs replaced.
To determine which it is, you will need to turn off the water to the dishwasher, the valve for the dishwasher water is usually under the sink. Remove the hose/pipe from the dishwasher inlet valve. The image below shows the water valve as part 744, it is accessible on the front left corner once you take off the lower kick panel.
With the hose taken off of this valve (744) put the hose in a bucket or put towels on the end and turn the valve back on from under the sink. We want to make sure you are getting good water flow to the dishwasher, if this is slow then you will need a plumber to find out why the water in the home is slow if this is flowing good then you will need to replace the valve on the dishwasher (744), the part number to use when purchasing the new valve is WD15X10003
Posted on May 24, 2010
I have a ge profile washer and I get an e4 error code
Hello Lisa;
My name is Peter. I am a retired field service appliance technician.
You did not provide any information so I have to be general.
1.) I assume this is a clothes washer and not a dish washer?
2.) What is the model number? It should be on a label on the face of the unit after you open the door.
3.) The E4 error code on your model washer is an inlet valve failure. Does washer seem to fill up with hot and cold water at a steady rate?
Mar 20, 2015 | GE Washing Machines
Will run thourgh cycles but only a little water will go in
Check fill line for a kink, (remove kick panel on bottom of dish washer)
If no kink then replace fill valve. Unplug dish washer fill valve is where water line is hooked on.
Aug 10, 2014 | Frigidaire Dishwashers
Water filling
sounds like a faulty cold water solenoid
Sep 25, 2017 | GE WDSR2080D Top Load Washer
GE Profile Model WPRE8150K2WT will not fill up with water. Just had Harness fuse Kit replaced two weeks ago as agitation and spin had stopped working. Washer worked for two weeks and now this problem with...
check the back of you machine there is a little sieve where the water comes sometimes it gets blocked with dirt just clean it if not that its the water valve its is to change
Jan 27, 2014 | GE Washing Machines
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
Almost new GE quiet speed 2 dishwasher not working properly
look at the spray arms see if they are stopped up look at the little holes in it hot water cleans dishes always make sure you get the water as hot as you can stand it before starting the washer as new washer dont use as much water as older ones so you can fill it with cold water before hot gets to the sink
Mar 31, 2008 | Dishwashers
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
