Question about Husqvarna 44 61 268 272k 225 Chainsaw Gas Cap 501431402
Husq 350 runs with gas cap off but bogs and dies with cap tight
Your gas cap is bad, it's not letting the air replace the fuel that is being sucked out. there for creating a vaccuum..... buy a new cap.
Posted on May 13, 2010
Car idles fine, but sputters, bogs and dies if gas pedal is pressed.
new spark plugs this decade. (a tune up?0
the filter is part of all 60k tuneups. letting it clog wrecks good pumps.
my wild guess, its lack of fuel flow, do to old filter.
or low fuel pressure.
car is identical to a Corolla. so is not unique or rare as some Geo cars are.
the cam belt not changes, invites valve kissing piston tops. BOOM
end of engine. (costs more to fix then worth of car)
the word is bogging, my engine bogs
if if bogs WOT (wide open throttle) and dont catch up < ITS NOT THE TPS. ever.
tps bad causes short bogs, called hesitations.
The map sensor , is what measure air flow and the ECU matches fuel to this air flow.
my guess, is it does that, but fuel pressure is like 15PSI, bad.
Apr 14, 2015 | 1995 Geo Prizm
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
Poland chain saw will run great through a half a tank of gas then it bogs,dies & wont start back
When this happens just slacken off the filler cap, if it picks back up and runs ok its a blocked fuel tank breather.
Oct 19, 2011 | Garden
My 1984 gmc with a carborated 350 starts runs and idles fine but bogs at half throttle wont rev up will drive at nearly an idle but any sort of gas it bogs and almost dies i used carb cleaner yet it still...
it could be a fuel blockage or it could be that the main running jets in the carby are blocked you may have to remove the carby & strip it down & blow it out with compressed air, but check for a fuel blockage first........hope this helps......cheers.
Jul 19, 2011 | 1984 GMC C1500
I got a 1993 geo storm, the car only has one mod, a cold air intake, but this is what happened, I was driving and the car would not go over 2k rpms, it was moving and running, but I floored it and...
Is the catalytic converter original? sounds to me like it just might be clogged in the short period car is running how hot is the catalytic getting (careful when touching sounds to me like its getting really hot) check all intake and throttle body bolts for tightness intake boot not cracked all intake clamps tightened and checked for good seal.
Nov 17, 2010 | 1992 Geo Storm
My ryobi will start but dies about 5 minutes later
Try running the machine with the gas cap loose. There could be pressure builiding up in the system due to the cap being too tight. There is no vent on these systems like an automobile. If the gas cap is overtightened this could be your problem as the cap is equipped with a gasket that allows the vapor to vent through the cap. Overtightening could be sealing off your vent
Jun 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2006 Arctic Cat ATV dies after about 15 minutes of riding
Sounds as if the gas tank is not breathing properly. The next time you run it, when it's about to die, loosen the gas cap. It should begin to run again. This is a sure sign that your gas cap is clogged. Clear gas cap of debris, or buy a new one.
Jim
May 30, 2009 | Swisher Atv Tru Plow
Husqvarna 44 61 268 272k 225 Chainsaw Gas Cap 501431402 Logo
214 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
sgtstrat
Level 1 Expert
ken skalski
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
