Question about Uniden Cordless Phone
How to set caller ID
How do i set a name to a number
    Brigadier General:
  • 7,191 Answers
Thanks for using FixYa.
Kindly let us kow the complete model number of the phone.
Posted on May 14, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Droid z992 shows restricted number rather than my name on recipient phone. How do I fix this.
Caller ID blocking feature may be on go to Settings and then tap on Call on a android phone
From there, tap on Additional Settings and in there, tap on Caller ID
just set the Caller ID to show Number" and it will be unblocked
Oct 03, 2015 | Cell Phones
How do i set up my caller id on the samsung B2100?
To set Caller ID you need to save the persons name and number within the PHONE MEMORY, once saved then go to 'My Photos' and select appropriate photo and select 'Options' then '5.Set As/Caller ID' then search for relative number on the PHONE MEMORY once found confirm it by pressing left soft key which will save picture to number.
Jun 12, 2011 | Samsung Lands Phones
How do i get my lucent partner 18d to show caller id name & number
2 line caller id is offered on newer versions of software. On earlier versions a call id name button is used to toggle between the clid name and number.
To program a button on your set press feature 00, press a button you wish to program as clid name,
and press feature 16, press feature 00 to exit programming. Press the button to toggle from clid number to clid name
Nov 03, 2009 | Lucent PARTNER18 Corded Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller ID
yes
Menu-settings-call settings- show my caller id-set by network
Or if u are using postpaid connection may be ur clip facility is deactivated
Aug 11, 2009 | Nokia 2630 Cellular Phone
Cect i9 caller id does not show names
let me give you an eg:
i stored an number 984802338 in my mobile with name jhon in my sim, when he calls me up it doesnt show the name.
It is because when he calls me, i observe the number it starts with +919848022338 so it is quite different from the number(9848022338)  you stored in the sim so you caller id doesnt show his name and shows as new user.
so 9848022338 is quite different from +919848022338(here +91 is country code)
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
Caller ID
just go in the settings of ur phone and then phone setting or in contact setting
Jun 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Numbers but no names
It's possible that the listing doesn't have a name. I know on my phone, that's the case. There may be a setting I'm unaware of though. Good luck!
Mar 25, 2008 | Panasonic KX-T7731 Corded Phone
Uniden Cordless Phone Logo
53 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
