Question about Keurig B70 Coffee Maker
My Keurig B70 has stopped working correctly. It is 16 months old and I make one or two cups a day. When it says "ready to brew", I put the kcup in and press "brew" and the machine begins to pump, then just suddenly stops. It doesn't make coffee and the window says "ready to brew" again. The water tank is full, I've cleaned the needles, I have descaled twice, and I don't make cocoa just coffee. Can you help me?
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
SOURCE: MY b60 all of a sudden won't fill a full cup when
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
Posted on Dec 31, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Posted on Mar 23, 2010
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
Why are all lights flashing on my keurig kcup maker
lights are flashing because you need to decide how big of a 'cup' you want to brew. When you push one of the flshing brew buttons, the unit will brew and the lights will then stay on steady until you reopen and add a new K-cup.
Apr 15, 2013 | Keurig Platinum B70 Coffee Maker
It won't brew when i put a kcup in but as soon as i take the kcup out i have no problem with the water going through
Be sure to clean the nozzle in the bottom of the cup holder and retest, but if this machine is more than 3 years old, the pump is probably bad. I have had several of these fail. Keurig says this is not repairable - just buy a new one (get someone on the phone.) They have always offered me a fair trade-in value against a new one. For me, 2 or 3 years from one of these machines is acceptable given the convenience and quality of coffee every day.
Mar 20, 2010 | Keurig Platinum B70 Coffee Maker
My 9 month old machine only spits out water for a second
I called Keurig and they felt that it was likely a blockage at the needles, but despite cleaning them repeatedly, there was no improvement. They are sending me a replacement.
Sep 16, 2009 | Keurig Platinum B70 Coffee Maker
My Keurig is leaving a lot of coffee grounds in the cup
I found that the kcups were under pressure. When I insert the kcup, I press down on the cup to puncture the bottom of the cup then close it. Works fine now.
May 16, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig B70 Coffee Maker Logo
479 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
