Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Lacie d2 Quadra 750gb HD, making werring,clicking noise.
My Lacie has recently started making a werring and clicking noise and not backing up. It also ejects itself off my power book . I have tried taking the lead out of my power book and re plugging it in but is now not recognising the lacie at all and when I try to back up maunally a note pops up to say there is no disk available to do this this. It is only 2 yrs old with a lot of spare disk space available. Any Ideas ???
  • 6,831 Answers
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Posted on Jan 25, 2011
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How can i open lacie and retrieve "my documents" folder?
Go to MY Computer.There you will find any device.right click on it and click open.
Oct 23, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
LaCie d2 Quadra is inert: service/repair or buy new one?
Check with LaCie's support site at http://www.lacie.com/us/support/ and it's a good idea that you write down the serial number of your external disk.
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
My LaCie 500GB Quadra spins and clicks. Have tried (Mac) DiskWarrior and Disk Utility, but the drive ignores them and spins, clicks, and the blue light flashes
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Sep 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computer doesn't recognize my Lacie HD
From your description it sounds like you power adapter did indeed fail at first, but if the HDD spins now the adapter seems to be working fine at the moment. If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Dec 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Nov 19, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
386 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
