Question about Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834)
Linksys EZXS16W switch, ports 1,2,3,4,9,10,11,12 do not work. #16 is used as uplink to Linksys router.Screen message says NO IP address assigned. Windows attempts to assign IP address and fails. Other ports function properly.
  • 153 Answers
I can give you the full manual of that product bro but you should have to install a foxit reader in order to read the file or the manual. First intall this software: http://www.mediafire.com/?nyowk0a5yqm Linksys EZXS16W manual: http://www.mediafire.com/?tgkdwnkjz1g
Posted on May 14, 2010
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
LinkSys router early deaths
Your cable modem has a ip address of 192.168.1.1 and your router probably has the same ip address. Hook your computer up to the router and change the ip address to 192.168.9.1. On your router change the router mode to static ip address mode. Then you will need to know your username and password from you cable company, and the Domain Number. Then connect the cable back to the wan port from the modem and the other end to the wan port of the router. Connect the computer to the first lan port on the router and type 192.168.9.1 go to the status page and tell it to connect.
Your cable company is giving you one ip addres and have to pay for another for more than one computer. What are you doing is using the router to receive the first ip address and distrubting out to the other computers.
Nov 24, 2009 | Linksys WRT160N Wireless Router
Linksys EZXS16W Issue
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Oct 28, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Linksys EZXS16w switch seems to have port problems
if they are blinking green, they are all working.
check your cable if they have continuity and also if they are patch cable
Mar 23, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
I cant login to the motorola login screen?
For Linksys routers there is no username only the password which is admin.
Dec 19, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Trying to connect two PC's to a Netgear FE108 switcher and a Thompson cable modem. Modem is connected to "Uplink" port on switcher. Normal/Uplink switch on switcher is set to "Uplink" Can connect one PC if...
Any network device, PC or otherwise, needs an IP address assigned. So, yes, both your PC's need an IP address.
Assuming your ISP lets you have multiple PC's(IP's) then you'll have to use the IP space provided by your ISP. The default gateway would also be provided by your ISP.
The way you SHOULD do this is to use a router, linksys for example. This way you can setup you private network(I.E. 192.168.10.10 for example). This will hide and protect YOUR private space from would be hackers. The router would use the REAL IP address on the outbound side to talk to the cable/DSL modem.
btw...you can use the ipconfig command at the command prompt(I.E. a DOS window) on your working machine to see the DHCP address and gateway that was assigned. Sound like your ISP only allows you one IP. The router solution above will fix that and let you connect as many as you want because the ISP will only see the one IP from the router.
Dec 07, 2008 | NetGear FE108 8-Port Ethernet Hub...
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834) Logo
707 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
