Question about Nokia 6085 Cellular Phone
I need a replacement for the clear plastic panel that covers the main display. Can I purchase one on-line and have it mailed to me?
  • 54 Answers
Pretty sure you can get one cheap on eBay. I bought mine at shops in India for about $4 - not just the clear part, but the whole set - the front, back, everything. I fixed it up myself with a set of screwdrivers (the ones tiny enough and shaped correctly for opening mobile phones)
Posted on May 16, 2010
My Samsung UN46C6300SFXZA started displaying horizontal lines immediately after we moved it to our bedroom when we purchased a new one.
i think you have problem with a display 90% or flat cable between main board t-con and t-con too display is 10% possible
Mar 04, 2017 | Samsung Televison & Video
Where is the reset buttun of algebra fx 2.0 plus calculater? i cant finf it
I need to know where I can purchase the plastic screen cover
on my canon mp49d calculator that displays the number. I
need to replace the one I have, it's cracked and i can't really see the numbers clearly. Can someone tell me where to purchase
this part without buying a new calculator.
Sep 23, 2013 | Office Equipment & Supplies
Visio VO420E, The left side of screen has a 6 inch wide group of colored lines, I removed the cover and the lines are directly in front of the main circuit board area (not the power supply board). Do I...
Lines like that are almost always a bad LCD Panel, but just to test...
Bring up an onscreen display (setup menu, volume bar, etc.) that originates from the TV ITSELF, not your cable, satellite, etc. You need something that intersects the area of the screen where the lines are.
1) If the lines are through the onscreen items as well, then it is a problem with the LCD panel. It sounds like you are fairly comfortable inside the set. First try to re-seat the ribbon cable(s) inside that are attached to the main board, insuring they are secured properly. See if that clears up your problem. If not, it's time for a new set.
2) If the onscreen items are OK, and it only affects the input source (tuner, HDMI, etc.) then it is most likely the main board that is having the problem. Replace that and you should be good to go.
Sep 15, 2012 | Vizio VO420E 42 in. LCD TV
I have a Whirlpool washer... model number # LSQ8243HQO The top part of the agitator is loose. The bottom part is strong. I think I need what they call dog ear replacements. Can you help me?
yes sounds like the dogs to me.
to replace them,remove the cap at the top off of the top of agitator by pulling it up (no tools required) then remove the clear plastic cover by pulling on one of the two tabs in it,remove the bolts using 7/16" socket and pull the agotator out of the machine by gripping it at the bottem.seperate the upper portion of agitator by pulling it upand the dogs will be located under the clear plastic,to replace them seperate the top barrel of agitator a cam that holds all (4) dogs will come out remove the retainer over the dogs install new ones and reassamble in the line up upper barrel and main agitator you will (2) tabs on main agi. and (2) corosponding slots on barrel line them up and snap in place
Jul 14, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
LOOKS LIKE SCATCHES BUT THE SCREEN ISN'T SCRATCHED AND BLOOBS OF LIQUID ON THE INNER SCREEN. A LINE DOWN THE CENTER OF THE SCREEN TOO
That really sounds like the LCD screen is cracked. The front will not feel cracked because of a clear plastic cover sheet but behind it is the LCD panel. The liquid you see is part of the screen leaking. The LCD actually means "liquid crystal display" and that is what you are seeing leak out between the cracks in the panel. You will need to have the panel replaced to clear the problem. You can get the panels from Ebay if you want to do the repair yourself. This type of repair is not covered under the Acer warranty. If you have any questions just use the email address below.
Buddy
Corporate Computer
www.ccl-la.com
h@ccl-la.com
Dec 16, 2009 | Acer Aspire One PC Notebook
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
Lines on upper left corner, inside of screen
its problem with the display cable (not the one you connect to your pc)
open the lcd display and look for a cable that is attached to the front glass display. check whether it is dameged.. it cannot be replaced
you need to replace the whole display that would be better. and cost effective
Jun 11, 2009 | Princeton Digital VL1918 Monitor
Marantz 2270 receiver
The lights are on the other side of the display. They have a plastic "wave guide" that deflects the light where needed. I hope this helps...accordianman
Jun 14, 2008 | Audio Players & Recorders
Samsung m500
Got the same problem here :( The phone actually powers up but the main display is messed up. Does anybody know how to remove the main display? I have removed the 2 hidden screws and tried to pry off both clear plastic display covers to no avail...
Feb 10, 2008 | Samsung SPH-M500 Cellular Phone
Nokia 6085 Cellular Phone Logo
69 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
