Question about Singer Sewing Machines
Waar kan ik een nylon tandwiel voor een Singer
Kan IK EEN waar nylon tandwiel VOOR EEN Naaimachine Singer type 258 Kopen.
3 Suggested Answers
  • 20 Answers
SOURCE: steken overslaan
Hallo, ik weet niet wat de oplossing voor uw probleem is, maar u kunt voor een gebruikers handleiding vragen bij http://www.brother-usa.com/manuals/default.aspx?PGID=17 klik op "Don't see your model listed here? Click Here" en vul het formulier in. Het spijt me, maar mijn Nederlands is niet goed. Groetjes
Posted on Feb 27, 2010
Testimonial: "bedankt, ik hoop dat het lukt om de gebruiksaanwijzing aan te vragen. bedankt voor het meedenken. Groet, Hetty"
  • 136 Answers
SOURCE: Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Posted on Mar 19, 2010
What is the bulb for the 258 singer sewing machine
Singer has the parts list for the 258 on their support site: http://www.singerco.com/support/replacement-parts-chart . The direct link is http://parts.singerco.com/CPpartCharts/2_2999/258.pdf . The lamp is shown on page 6. The part number is 603938-001 or 603938-002 (Light L 11) depending on if the machine's motor is UL or Standard. Amazon has a couple of vendors that list the 603938 bulb. One of the vendors is http://www.amazon.com/Singer-Long-Light-Watt-120-Volt-Push-In/dp/B0001DUOSY .
I hope this helps.
Sep 24, 2015 | Singer Sewing Machines
Will the bed plate from any other singer machine fit the 258 from 1974? I can't seem to find the 258 bed plate anywhere.
Did you contact support at Singer? Did you google it? Did you check with a sewing machine repair outlet?
Jul 13, 2015 | Singer Sewing Machines
Naald raakt raakt de spoelhuisrand
Assicurarsi che l'ago sia correttamente. Assicurarsi che il lato piatto dellago sia rivolto sia anteriore o posteriore, qualunque sia il vostro manuale dice e il modo corretto. Inoltre, essere sicuri che si sia spinto fino nel supporto. Svitare la vite che tiene il piccolo ago, ed estrarre lago in modo da poter essere sicuri che il lato piatto sia rivolto verso la strada giusta. Poi, muovere lago mentre si spinge verso lalto nel supporto e stringere saldamente la vite piccola che tiene l'ago nel supporto. Buona fortuna
Apr 06, 2013 | Singer Inspiration 4205 Mechanical Sewing...
How to oil a singer fashion mate 258
Try searspartsdirect.com
They have all brands.
Sep 02, 2012 | Singer Sewing Machines
Spanning voor bovendraad werkt niet meer
Maybe the thread is not in the correct position between the discs on the tensioner. Is a tension spring broken?
Join the Pfaff user group on Yahoo... they have ALL the answers.
http://groups.yahoo.com/group/pfafftol/
May 06, 2012 | PfaFF Creative 7570
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
Steken overslaan
Feb 27, 2010 | Sewing Machines
What type of bobbin does an old Singer Stylist
457 made in the late 60's, you must use Singer plastic bobbins, you can get them on ebay easily enough and cheap, most common fault is the nylon gear breaking up after many years but even that is easy to do.
Feb 20, 2010 | Sewing Machines
Singer 258
Jan 15, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Mar 25, 2009 | Yamata FY14U4AD
Sewing Machines Logo
78 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
