Question about Iomega Zip 100MB (31714) External ZIP Drive
Disc won't read
On the drive the light flashes, I could hear it trying to read the disc but nothing happens.
  • ddanem Apr 01, 2008
    Problem not solved
  • Jimbo3625 May 20, 2008
    I am having the same problem: the drive clicks a lot and is definitely powered up, but nothing shows up on the desktop. I have an iMac OS 10.4 and a Zip 100 drive. The disk is also a 100MB disk.
    Thanks for any help you can provide.
  • 59 Answers
What type of zip disk are you trying to read? if it is larger than 100MB, the drive will not be able to read it.
can you read other disks? can you see the drive in my computer?
what operating system are you using, and how does does this drive connect to the computer? USB? Firewire?
Posted on Mar 29, 2008
I droped my firelite and now it won't read. I plug it in and hear the disc startup, the blue light flashes once and then three times in a row. Can I transfer the disc to another housing?
it sounds like you have damaged the disk itself. most portable hard drives are just notebook drives in portable enslosures. The same think happened to my WD portable and I had to trash it. I saw the same symptoms and only after playing with it could i get it to read but only with 2mb since the disk was cracked. hope this helps you.
Apr 08, 2010 | SmartDisk FireLite 40 GB Hard Drive
I have a dell latitude D620. and it wont read from the cd/dvd drive. when the disc is inserted you can hear the disc start up and rotate and see the cpu light flashing but nothing else happenshen...any...
The Readhead off the drive is broken and refuses to move.
only way to fix this is change the cd/dvd drive.
This is your solution. Please vote!!!
Jan 18, 2010 | Dell DVD-rom DVD Drive
My Toshiba Satellite A215 S4757 cd/dvd drive won't read any discs. I can hear it trying to read the disc, but then nothing happens and the disc pops back out.
hi
try to clean the laser lens with a ear bud and metholated spirits and wait for it to dry (5mins) and then try again
Apr 26, 2009 | Computers & Internet
Our hp pavilion 4535 will not read discs
I'm thinking of a couple of solutions:
  1. Auto run as turned off, navigate to your drives (usually in the My Computer icon) and check for your disc drive (usually Drive D:). If it is showing a disc then you can right-click and open to see the contents or double click for an auto-play.
  2. If you open up the drives and don't see a CD ROM drive then it might have gotten dropped some how. In this case you will want to go to the device manager and check to see if the CD ROM drive is listed and if it needs some fixing.
Mar 13, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Laptop not recognizing CD drive F
the yellow exclamation mark, states that the device is not functioning correctly.
options are:-
1:) go to the manufacturers website, and see if you can download a driver for this.
2:) try uninstalling the device, reboot and see if the device manager, finds new hardware, if so reinstall the device drivers.
3:) eject or remove the device, re-insert ( possible dirty-bad-loose Connection.
Mike @ Compurepair.
Nov 05, 2008 | Medion md40298 Notebook
Iomega zip port
First of all, make certain you are only using 100 MB disks in a 100 MB reader.
If the problem is more complex than that, I have several questions:
Can you read different disks?
what type of connection is the zip drive using with the computer? USB?
does the zip drive need an external power supply?
will the zip drive successfullly read disks when connected to a different computer?
does the zip drive appear under my computer at all? even as an empty drive?
what operating system are you using?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
Psps does load any discs
Ok Crowd,
All of you need to send your PSP off for repair. The UMD drives not reading is common fault of the PSP and the drive will need to be replaced. The power on Problem is possiblly a defective motherboard. They can be repaired.
Click on "Repair Directory" at the bottom of this screen. Then select "Video Game Consoles" on the next screen. Pick a good REpair shop that has experience in repairing PSP's. Ask them if they know what a UMD is. Then Ask them if they have ever replaced a UMD drive. If so they know what they are doing. Find a good price
Nov 12, 2007 | Sony PlayStation Portable (PSP) Console
Can't read, burn cds
have you tried different cds? or just 1 same cd?
Oct 19, 2007 | Compaq Presario 5000 PC Desktop
Hi Tubston1980,
What we have here, is a failure to read the UMD.  Troubleshooting 101,  open the UMD door and depress the little black spur sticking up about 1/8" and it is about 3/4" in and to the left.  Once your depress the Black spur, You should see the the little disc motor spin and the laser beam light up.  Do not stare into the laser. This tells you that at least the laser is lighting and the motor is turning,  Now, get a Q-tip and dampen it with Isopropyl rubbing alcohol.  Rub the lens with the dampened q-tip.  Use the dry end of the Q-tip to dry the lens. Look carefully to see if any lint or foriegn obsjects are inside the UMD disc drive.  If you see anything, get it out. Look at the white gear in that back to see if anything is on it. Clean it if necessary, I know its very close quarters and hard to do.
I repair PSP's with this problem that do not get fixed after cleaning. I can replace your UMD drive with a full brand new drive for $47 which includes Return shipping. Contact me at Repairtech@playstationclinic.com if you need further assitance.
Oct 15, 2007 | Sony PlayStation Portable (PSP) Console
Iomega Zip 100MB (31714) External ZIP Drive Logo
153 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
