Question about Nintendo Wii Console
Wont let us connect to internet error code 51030
    Genius:
  • 1,234 Answers
Error Code: 51030 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Posted on Aug 25, 2010
SOURCE: cant connect my wii
contacted nintendo support and was given all the help i neede to resolve the problem, everything now works fine thanks.
Posted on Jul 20, 2008
piyush dixit
  • 136 Answers
SOURCE: cant connect to the internet
Check for interference that may be successful connection.
Thanks,
Posted on Nov 17, 2009
  • 85 Answers
SOURCE: connection to internet error code 51030
Do the internet connection test and see if it has a problem, if it does, then reset your wii internet again and it should work fine. This can occur rarely. Hope that helps.
Posted on Jan 19, 2010
  • 6 Answers
SOURCE: how do I connect to the internet to use the
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again.
Then, click the one you have access to...
click OK once you've selected your connection, it might ask for a security key if you have one set up.
it should test the connection.
If this is the first time you've connected your Wii, it will most likely update your system
Posted on Apr 16, 2010
  • 839 Answers
SOURCE: error Code:51030 Unable to find an accesspoint.
most efficient and best way is to download all the repair guide and keep it in our system, we can use this for our personal future use...
click here to download repair guide
Posted on Dec 15, 2010
Netflix connection error code 51030
if this is on a wii that error code means no internet connection check your wireless settings
Sep 09, 2011 | Computers & Internet
Why is 51030 coming up why im trying to get on the internet on my wii.
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51030 is:
"Error Code: 51030Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Apr 29, 2011 | Nintendo Wii Console
51030
"Error Code: 51030
Apr 27, 2011 | Nintendo Wii Console
Trying to set up net flix what is theSSID meam and code 51030
SSID is the name of your wireless network on your router, code 51030 means your not connected to the internet or you have a problem with the wireless connection from the wii to your router
Mar 23, 2011 | Nintendo Wii Console
Error code 51030 keeps on poping up
Error Code: 51030 (unable to connect to your wireless network)
Check this link -->http://www.nintendo.com/consumer/
Feb 19, 2011 | Nintendo Wii Console
Trying to hook up to are nintendo so we can get movies from netflix, ran at test got error code 51030 please let me know what to do if anything. thanks
The error code 51030 means that you have and internet connection error. Possibly caused by being too far from the wireless source, or your wireless settings on your Wii need to be adjusted. Here is a link to Nintendo's Customer Support to show you the steps to set up, or reset your wireless connection.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Oct 28, 2010 | Nintendo Wii Console
Connection to internet error code 51030
Jan 17, 2010 | Nintendo Wii Console
Cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Oct 19, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
322 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
