Question about Bulova Watch
How to set aquastar solar watch 3906 - Bulova Watch
How do I set the date on a SKMEI 1064
Go to:
http://www.aliexpress.com/item/New-2015-Men-Sports-Watch-Digital-Quartz-Solar-Power-Watch-Solar-Energy-Watch/32275520722.html
Mar 28, 2015 | Watches
How to set the time on a casio tough solar?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
May 24, 2011 | Casio Tough Solar Watch MTP1227
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
I cant set my aquastar solar wrist watch
A lot of users are having trouble getting this watch going. Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Direct link for the W-207 movement:
http://assets.timex.com/user_guides/W207_M115/W207_M115_NA_EN.pdf
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 04, 2010 | Timex 1440 Prizefighter 53032 Sports...
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Jul 04, 2010 | Watches
How to adjust the band on a GW800D Tough Solar
By finding a spring loaded rod in the clasp (that is in the set of three holes in the clasp) moving it to the last position. However it was still loose, so by finding the spring loaded rods that hold the links of the band together, pushing them down in the direction of the arrows and removing enough links to fit.
Aug 29, 2009 | Casio GW800D 1V G Shock Atomic Solar Watch
Setting time for aquastar watch
joe WANT TO KNOW HOW TO SET THE TIME AND DATE ON A AQUASTAR WATCH# 3876.
Feb 29, 2008 | Timex 1440 Prizefighter 53032 Sports...
Manual
My victorinox 24731 has gone silent. the alarm sounds if i lift the back flap and push a little black disc in the rhs bottom corner. but it does not work when i set it . it has been working perfectly for the past six months
Sep 18, 2007 | Casio G7301V8V Tough Solar G-Shock Gray...
Bulova Watch Logo
88 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
