Question about Maytag Neptune MAH5500B Front Load Washer
Spin cycle will not spin. what could be the problem
    President:
  • 2,468 Answers
Its in the control board,you need to open the top and access the tech data sheet for the machine and run the diagnostics on this sheet,it should point to the problem
Posted on May 13, 2010
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Whirlpool ultimate II washer will not spin everytime in the normal spin cycle
Hi, Ginger. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Aug 23, 2014 | Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
