Question about Acer Aspire X1200-B1601A PC Desktop
The cd rom on my acer x1200 is not working. When I load a cd into it, it won't start up
    Scholar:
  • 94 Answers
Just check the connection of your cdrom on the My computer if they have appear. If the cdrom was display in the My Computer just clean the cd lens of that cdrom. Remove the cdrom from your computer and open the cd lens then clean it by the piece of cotton and add a small amount of alcohol then rub on the cd lens. After that insert back the cdrom then try to power on your computer and if the problem are the same not solved. Just replace the cd lens of your cdrom, But if the cdrom was not display in the My Computer just check the connection inside if the power supply of the cdrom are connected to its back.
Posted on May 29, 2010
My cd /dvd rom (dvd/cd burner) is hide..my pc doesnt recognize it..help please..i dont know if i lost a driver
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 26, 2013 | Acer Aspire X1200 PC Desktop
How do I restore Acer Aspire x1200 without disc?
Hi dustinwilkin From http://www.geekpolice.net/t7449-acer-system-recovery-partition-hotkey-instructions-erecovery : To access the recovery partition on your Acer computer for recovery, follow the steps listed below.
1. Power on the computer
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery.
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit
Note that all data will be lost during this process and your computer will be brought back to it's original factory state and settings. Best regards , fanaudi .
Sep 29, 2011 | Acer Aspire X1200-B1601A PC Desktop
There is not an emergency DVD eject hole that is evident anywhere on the front or side of the Acer x1200 desktop. I have done this on other computers before so know what to look for. When I push the button...
Is your optical drive hidden by a panel? Some computers have this cover that should flip down when the drive opens and close when you close the drive. If this is the case, you need to get behind the cover to find the manual eject hole. For whatever reason, I can't get the Acer manual to load today so I can't quickly check how to remove the entire faceplate from the computer.
http://support.acer.com/ is a good starting place.
Since the drive is recognized by the computer, I suspect the cover may need adjustment (or the cd tray isn't pushing hard enough).
I hope this helps.
Mar 01, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
A mini camcorder dvd is stuck in my computer cd rom drive. how can i retrieve it?
You can use something sharp to stick the small hole of your cd drive. Then your disc should be enable to eject. Feel free to visit DigitalSupportTech if you need further help.
Oct 09, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
My internet wont work anymore because i downloaded an update ( Windows home premium) on my acer x1200 I want to wipe / recover my computer to its original facttory settings but ive tried everything. I dont...
Click: Start
Click: All Programs
Click: Accessories
Click: System Tools
Click: System Restore
Pick a "restore-point" that was taken _before_ the update was applied,
and restore your system to that previous date/time.
OR ....
Look under "All Programs" for a utility that will help you burn CD/DVD(s) to create a "Recovery Disk" set. Burn more CD/DVD(s) with all your "data" files (or copy all your data-files to an external hard-drive). Then, boot from the "Recovery Disk", to begin the process of restoring the "factory" settings.
Sep 10, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Acer aspire 5100 cd-rom issue
You can try deleting upper and lower filters. This solves many CD/DVD drive-related problems. The steps are outlined here:
http://support.microsoft.com/kb/314060/
Jan 28, 2009 | Acer Extensa 4620 Notebook
The exact same thing happens to me all the time. I don't have a solution I need one. As far as I can tell the only way out of this
Aug 04, 2008 | Acer (91.AB264.023) Internal 32x CD-ROM...
Acer Aspire X1200-B1601A  PC Desktop Logo
256 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
