Home | Relisys | RLT1720 (Black, Silver) 17" LCD Monitor | Lcd monitor goes bla...
Relisys RLT1720  17" LCD Monitor
Problem for Relisys RLT1720 (Black, Silver) 17" LCD Monitor
Lcd monitor goes black after 5 seconds
By llme on Mar 29, 2008
i have a MAG LCD monitor LT1919WDb, i turn it on and after about 5 seconds it goes black, the power light stays on and if i power it off and on it does the same thing. it is a year old. it has vga and dvi inputs, i've been using the vga because i don't have dvi on computer. i don't even have enough time to see if it is set for vga or dvi. the computer works fine with other monitors. i talked to their tech support and they said if it comes on fine for the first 5 seconds then the video card in the computer is compatible. they suggested bringing it into the shop, $100 plus parts, not worth it, any suggestions???
Same Problem
Jan 09, 2009
-   FOLLOW UP. The temporary fix lasted three days for me. Now the monitor is doing it again regardless of the brightness setting. Game over.-   robertwayne
Jan 06, 2009
-   I purchased two MAG LT1919WDb monitors at the same time and ran them side by side on my office computer as dual monitors. I purchased them in March of 2007. Last week (January 2009) one of them went black and is doing the exact same thing as described in this post. I just wanted to add that I tried both DVI and VGA inputs and had the same results. I had the brighness on 70 prior to the issue. I lowered the brightness down to 10 and the monitors seems to be working. I adjusted it up and made it to 43 before it went black again. I backed it off to 40 and it seems to be working. I just did this right now so I have no idea how long this will work. I will try to follow up. I am going to try to get by with this level and put off replacing the monitor as it is a secondary monitor anyway. -   robertwayne
Sep 19, 2008
-   My monitor is first generation KOGI 14inches, it is old but rarely used.
Recently the same thing happened. Sometimes the sreen was so dark that the windows was almost invisible and sometimes it may work fora whole day with any problem. But more frequently, down in a few second after turn on.-   Guest
Apr 14, 2008
-   I am having the same exact problem. Several days after the warrenty runs out it does the same thing. It goes black after 5 seconds.-   Jeffery1
Best Solution
posted on Apr 14, 2008
Helpful)
Jeffery1
Rank: Apprentice
Rating: 85%, 1 votes
I have read it may be an inverter. Anyone know what that is or where I can get one for the mag lcd moniter lt1919wdb?
Comments:
Apr 14, 2008
- Ok! I guess I am an apprentice now hoping to be a pro soon. Anyway, I read about using a flashlight and shining it at an angle to see if I could see my desk top icons. Yes it worked. I then lowered my brightness to 20 and the monitor works now. I am afraid to move it brighter. Anyway, it should last till I get a new one which it wont be a mag!!
Was this helpful?
Yes
No
Solution #2
posted on Sep 23, 2009
Not Rated)
mjs338
Rank: Guide
Some new capacitors on the vga converter board. Which ones, i don't know for this model.
Was this helpful?
Yes
No
Popular Solutions for Relisys RLT1720 17" LCD
Questions and Unsolved Problems for Relisys RLT1720 17" LCD
Do you recommend Relisys RLT1720 (Black, Silver) 17" LCD Monitor?
Answer
Answer
My relisys lcd tv has sound but black picture. Can i fix it and where?
Answer
how do you tune a relisys tv I have done an auto tune but need to tune manually fine tune has a... (More)
Answer
any suggestions on how to repair and where to buy parts?
Answer
hello all! my name is theodor and I have a problem with my Relisys lcd tv monitor 1720.I need to bye... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Relisys RLT1720 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
