Question about Nokia 2126 Cellular Phone
Tracfone dies after adding time
I redeemed an airtime card for tracfone on their website and after adding the time my phone didn't update so I turned it off waited a little bit and turned it back on. It went to start then vibrated and beeped It does this every 4 or 5 seconds until I remove the battery which is the only way to get it to stop. I called tracfone and they said the phone is no good. I believe something happened to it during the update and I know this has happened to others. Any ideas about this?
Thanks
  • 2 more comments
  • jahcdale Aug 14, 2008
    I had this exact same situation occur on my wife's Tracfone. Tracfone says there is no solution but to buy a new phone. This was an obvious software sync error that occurs when adding minutes on-line at their website...not a coincidental phone death that happened when adding minutes. What worked for me was to press both the green and red keys simultaneously when powering up the phone. This brought me to a time screen that I OK'd out of and then the phone went back to it's normal menu screen. Try this before buying a new phone and remember those prepaid cards are non-refundable.
  • drew02 Sep 18, 2008
    I have the same problem as described by the others above. I also got the same runaround from Tracfone. "Not their problem, the phone is broke" I did get then to refund the cost of the minutes I wanted to add. I'm still looking for a solution as those listed did not help. Thanks
  • jakrause Jan 06, 2009
    I had the same problem everyone has listed. I called Tracfone and told them I believed it was a scam to get you to buy a new phone and loose your double minutes previously purchased. Of course they assured me it was just a coincidence that my phone died at the exact time I was adding minutes. Anyway, I attemped the suggestions to get it to work and on my third attempt of turning the phone on while punching random keys it came back to life. I think Tracfone sucks for treating its customers this way!
  • Brendan Parker May 09, 2013
    OK! I pulled the battery out and put it back in and it worked. Not cool, tracfone. You know, you'd think a company who provides a phone service would have a live chat on their site for people who need immediate assistance because their phone doesn't work. :/
Same problem. Working off of Reijose's suggestion (thanks) I had the charging plug in the wall and the phone. That at least stopped the buzzing. Then I started working combos of buttons, turning the phone off and on etc and finally it came back to life. Can't say it was any one combo, but I did press 666 and clear or stop enough times that I might have finally exorcised the demons of of this thing.
Serriously that was the combo of buttons I used, through just by chance more than anything, ha.
Posted on Sep 18, 2008
I just had this problem, and I got it to work again by pushing the power button a bunch and at the same time putting the charging plug in and out quickly (while it was plugged into the wall).  I just kept messing with these two things at the same time and it magically came on!  I have no idea why this worked!!!???  hope you can get yours to work. best of luck!
Posted on Aug 05, 2008
THANK YOU GUYS SO MUCH!!! Pressing the red and green keys after hitting the power button worked for me also. I had just added 120 minutes, not by the internet though, on the phone itself and when I turned it off it would not turn back on. I was almost in tears.
Posted on Dec 12, 2009
Same problem, phone working fine, added minutes online and phone died. Would flash white screen and buzz/beep every 10 seconds. Called Tracfone, they said get a new phone. Did what was suggested by several people above, popped battery in and out, held down start key and pushed buttons and all of a sudden it started working again. Red and green buttons didn't work, was some combination of numbers that finally fixed it. Thanks :) :)
Posted on Apr 19, 2009
Same problem as the others. This phone would turn on long enough to show the TracFone splash screen, play the intro notes and show the battery meter. Then it would go black.
A white screen would show for a while if you pushed a few buttons.
To get it working...I took my que from jahcdale's post, where he held the red and green buttons while he turned on the phone. That didn't work for me, but this did ... I left the battery cover off so I could take the battery out quickly in between attempts. I can't say which buttons worked the magic but I held two or more buttons down and turned the phone on. If it didn't work I popped the battery out then back in and tried again. Took about fifteen minutes of that kind of foolishness but it did come back to life. I was holding * and #, then # and red, * and green...whatever...you get the idea...just keep abusing the start up sequence till it un-hickups and comes back to life;-)
Posted on Aug 30, 2008
I hate tracfone! it's always a hassle to add minutes. I had this exact problem after adding minutes, and followed the on and off/removing battery pushing random buttons till it came back to life. I'm sorry i can't be more specific, I just kept with the on/off and battery in and out while pushing random buttons, sometimes two at a time, sometimes in sequence...I also screwed up and called that *22891 number to 'optimize' network capabilities...that's what kills them. tracfone wants these 2126's dead because often they give you free (no minutes deducted) texting. I don't know why, but mine used to fail to deduct the half minute when i sent or received texts... it would say '.5 units deducted', but my minutes would not decrease...anyway now that glitch is fixed...never call the optimize your network number. there's a utube post about this glitch, and it's not fake
Posted on Dec 25, 2008
An update would make it not turn on. It mat not be able to make calls but would still power up. I say it just took that time to die.
Posted on Jul 21, 2008
Where do I find my Service Plan PIN on my new Tracfone?
sometimes it does not pay to think before asking questions at time of purchase .
Nov 27, 2016 | Cell Phones
How/where do I find my voice, text, data, airtime TRACFONE available time still available?
How do I check my minutes on my Tracfone?
    Look at the home screen of your TracFone device, your Airtime Balance Display is shown directly on the home screen of your cell phone. Navigate from any menu or application directly back to the home screen to see your updated balance. View the balance by going to "Menu." Click on "Prepaid" followed by "Airtime Info."
    Additionally, you can enter the following URL to check your balance: "https://www.tracfone.com/direct/CheckBalance?input_phone=1234567890" (replace 1234567890 with your phone number). You will get a text with your balance.
    And finally, some users are reporting the easiest way is to call *777*1# to get your airtime.
TracfoneReviewer How to Check your Tracfone Airtime Balance on Android...
Jan 08, 2016 | ZTE Cell Phones
Reactivated 5 hrs. ago. Unable to use phone. Message emergency call. What's wrong
Did you have a lapse in service?
Did you just add airtime after lapse in service?
You have added time but your sim card is not active, which is what Tracphone does when you have lapse in service.
You need to talk with their customer service reps who will help you get your phone up and running again.
Customer Support FAQ TracFoneWireless
Nov 27, 2015 | tracfone.com
How many minutes do I have left?
From Your TracFone Step 1 Look at the home screen of your TracFone device, your Airtime Balance Display is shown directly on the home screen of your cell phone. Navigate from any menu or application directly back to the home screen to see your updated balance.
Step 2 View the balance by going to "Menu." Click on "Prepaid" followed by "Airtime Info." This menu will also show your current airtime balance and expiration date.
Related Reading: How to Check Your Prepaid Balance for T-Mobile
Step 3 Add additional airtime to your account by calling 1-800-867-7183, refilling the minutes online or by visiting a participating retailer (see Resources). Enter the PIN number on the back of your refill card to add additional minutes to your account.
From Your Computer Step 1 Check your minute balance by logging in to your account on the TracFone website. Once you are on the homepage, click on "My Account." You'll be prompted to enter your username and password. If you don't currently have a TracFone account, you can register your phone number by clicking on "Register."
Step 2 Find the minute balance of your account displayed in the middle of the "My Account" homepage.
Step 3 View the account expiration date on the "My Account" homepage (see Resources). Your balance expiration date varies depending on the amount of the airtime refill card.
Oct 14, 2015 | Samsung Galaxy Centura Smartphone -...
My Time on my phone has lapsed.Do I have to by a new one?
No. You can just buy a new airtime card. Depending on how long it's been lapsed, you may need to contact Tracfone to have your phone reactivated. If it's been too long they may have given your phone number to someone else and then they'll have to give you a new number. But in any case, you don't need to buy a new phone, just more airtime.
Oct 22, 2013 | tracfone.com
Free airtime codes
To get free Tracfone Airtime codes, log on to the website and check for any free code options. Buy a phone combo. The phone can be recycled to get a 20 minute extra talk time. The Tracfone codes are entered through the website.
Aug 27, 2013 | LG Cell Phones
I have a TracFone Motorola and can't add airtime from prepaid card.
You may call Tracfone at 1-800-867-7183.
You'll find complete contact information here.
Aug 26, 2012 | Motorola Cell Phones
How to load more minutes onto a v10 tracfone
Click the center button in the middle of the central directional switch on top of your key board and the first option should read Prepaid, then click SELECT (top button on far left) and then use the DOWN arrow and go to the 7th option, REDEEM AIRTIME, and choose SELECT again then follow the directions and put in the PIN number from your new card or printed receipt and quickly you will receive a text back from TRACFONE confirming, and soon your new minutes will appear on your phones UNITS display.
Feb 28, 2009 | Motorola Mobility TracFone® V170 Cellular...
Nokia 2126 Cellular Phone Logo
1,057 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
