Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My epson stylus sx115 keeps jamming paper when printing
jackboy
  • 2985 Answers
SOURCE: Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Posted on Oct 02, 2007
Ajkill
  • 2035 Answers
SOURCE: Always Paper Jam in Epson Stylus CX3500
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 26, 2008
SOURCE: Epson Stylus 580rx won't identify vellum paper
This did work, but I tried something that worked better. Put the blue painters tape along the edge that you feed into printer. I put 2, one-inch strips along each end. The painters tape easily removes from paper, and there isn't a mess with ink along the folded edge of paper from above solution.
Posted on Oct 28, 2009
  • 1121 Answers
SOURCE: Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
Posted on Feb 09, 2010
  • 120 Answers
SOURCE: I have a new Epson
To remove your problem follow the simple tecnique.
1. Open paper feeder.
2. In the paper feeder you will see a white feed roller gide.
3. Remove the roll gide from paper feeder.
4. In the center of the roll gide you may see a spring inside it. Remove it and set all the parts of the printer again. I think you will be relive from your problem.
Thank you.
Posted on Sep 15, 2010
My epson stylus SX115 won't print out.....It says no black ink, but it has color........
Epsons will not print at all if ANY of the cartridges are empty. It doesn't matter whether or not you want to use the color exclusively or not.
Apr 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
ftp://download.epson-europe.com/pub/download/3233/epson323393eu.pdf
Mar 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I want to print onto a transparency from Epson SX515W. It keeps spitting the paper through and complaining about a paper jam. Paper didn't jam!
please go back to the set up of the printer, and the printing properties, and specify the paper type before printing, if this resolves your issue , get back to me
Regards....
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Feb 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Jun 14, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
479 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
