Does a msi u120 keybord fit a msi u130 computer
Download arccon.dll from
http://www.ziddu.com/download/9844903/ArcCon.zip.html and install it..
Step by step instructions, how to unzip your files from DLL-files.com.
Open the zip-file you downloaded
Extract the .dll-file to a location on your computer. We recommend you to unzip the file to the directory of the program that
is requesting the file. If that doesn't work, you will have to extract the file to your system directory. By default, this is
C:\Windows\System32 (Windows XP, Vista, 7).(That means Copy the zip file you downloaded to C:\\windows\system32 and right
click on it and select extract here).If its asking for overwriting, select YES).
[To access system32 Type C:\\windows\system32 in RUN. OR go to C drive , then go to Windows folder and go to System32)
Make sure overwrite any existing files (but make a backup copy of the original file).
Reboot your computer.
If the problem still occurs, try the following:
Go to Start and select Run.
Type CMD and press Enter or OK
Type regsvr32 ArcCon.dll and press Enter.
Restart your PC.. now it will work
Link to download arccon.dll is
http://www.ziddu.com/download/9844903/Ar... and install it..
