Question about Nikon COOLPIX S5 Digital Camera
How do I take pictures from my memory and put them on my SD card?
Ok well the other day I was out and I accidently left my SD card at home so I was taking pictures. I lost my cord to plug my camera into the computer and I don't want to have to go out and buy one. Anyway so I took these pictures and I would love to transfer them to my SD card so I can insert that into my computer and get the pictures off the camera.
Do you know of a way I can get my pictures put onto my SD Card??
Thanks for any help!!!
  • Anonymous Mar 25, 2014
    I took pictures went ahead and put them on computer then I tried putting the sd back and now it wont hold the sd card
You'll have to buy the charger/station for S5. No other cord fits your nikon unfortunately.
Posted on Mar 29, 2008
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
I cant take pictures or videos since it says write protect on the screen. How do i fix this?
Take a look athe SD card in the camera to see if the little slide switch on the left side is down. That is the write protect switch of the SD card to prevent you from over writing data/pictures or formatting the memory device accidently. push the switch up and try again.
Jan 09, 2011 | GE Cameras
How do i transfer pictures on a samsug sch i760 onto the micro sd card?
    The microSD memory card MUST first be formatted, by the handset, in order for the handset to create the destination folders.
    To transfer the pictures, remove the memory card slot cover. Insert the microSD card into the slot until it locks into place. Press the OK key for menu. Select Get it Now. Select Picture and Video. Select My Pictures. Select desired picture. Press the right soft key for options. Highlight move and press OK. This puts the picture on the SD card.
Oct 22, 2010 | Samsung SCH-i760 Smartphone
When i try to take a photo with my KodakC180 Camera it says "Memory card is protected (Reset Switch on memory card)" And it has a thing that says Go to review. When every i click okay it takes me to the...
There is a little switch on the side of your sd card.The switch is the lock for the card memory. It's so you can't accidently delete something you don't want to. Move it which ever way it moves to and put it back in. It will allow you to take more pictures after that. Good luck.
Apr 19, 2010 | PNY 2GB microSD Memory Card
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
    Canon SD1200 IS won't save pictures to the memory card.
    This Canon uses an SD memory card (previous Canon used CF cards).
    The SD memory card has a "slide switch" that locks the card.
    Look at the SD memory card and move the switch back and forth, then switch it all the way to the UNLOCK position. Put back in the camera and format the card, then use it.
    Since this is a 10Megapixel camera, use at least a 2GB SD memory card. A 2GB SD card will hold 700 pictures, or so, in the best setting.
    Hope this helps!
    Sep 03, 2009 | Nikon COOLPIX S60 Digital Camera
    I can take pictures just fine but when I push the review button on the camera, it statesno images to display. I cannot review any pics and cannot download into my laptop, HELP I am trying to sell my home...
    if the display its ok ..I suspect something wrong with the internal memory ..try to remove the SD memory card and see if the pictures are actually stored on the card..and download directly from the card using a card reader ...if you only use the 32M internal memory and didnt expend on a Sd card ...probably its full or something wrong and do not store pictures anymore ..and thats why it doesnt sow'em anymore ...try to reset the camera to default setings Im not sure but all cameras have something lik ethis in menu...and try to see again the results...but if the camera works ok ..but cause a malfunction of software it do not sowa the pictures anymore ..the solution is to download from the SD mem card directly using a card reader ...most laptops have sd card reader ..and all picture printers read from the card too
    Aug 04, 2009 | Kodak EasyShare CX7530 Digital Camera
    Polaroid Memory Chip problem
    Hey ashley131,
    One thing that might be happening is your SD card is set to the locked position on the side of your card. If this is not the case you could try opening the card by going to My Computer and right clicking on the memory card icon, then left click on open, and if it opens copy all the files shown and paste them into a folder of your choice, and then try opening the files using windows picture manager. If this doesn't work there are memory card recovery programs you should be able to use to recover your images just do an internet search for memory card recovery software. Once you have saved your images to your computer I would format your memory card in your camera, and the card should be able to be used again. I hope this helps!
    Sincerely,
    Allan
    Go Ahead. Use Us.
    May 27, 2008 | Cameras
    Memory card problem
    Assuming your camera acts like a removable drive when connected to the PC try the following.
    1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
    2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
    3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
    4. Let me know if any of this works.
    Oct 22, 2007 | HP Photosmart M525 Digital Camera
    Nikon COOLPIX S5 Digital Camera Logo
    Top Nikon Cameras Experts
    Steve
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
