Question about Sub-Zero 661/F Side by Side Refrigerator
My sub-zero refrigorator is icing up on the first
My sub-zero refrigerator is icing up on the first 2 shelfs. I was told that it was becaues there was a pin hole in the coial and freon was leaking. That does not make sense to me because the setting is on 3. If freon was leaking wouldn't the unit be warm?
    Genius:
  • 1,400 Answers
Hello
There could be some other reasons for the ice.
1 bad or cracked door seal,have a look at the door seals.
2 Defrost timer may need to be set longer.
3 T sat set to low or not working properly.
Unit may be low on freon also,causing a lower pressure which would cause a lower tempreture,this occurs with a small leak or a pin hole leak.Once enough freon leaks out it will warm up and no longer work.
You can have a leak check done by a service person.
Posted on May 13, 2010
Testimonial: "I was very happy to get such a quick response. I may have not explaned the problem correctly but I did get half the answer. My problem is the refirgorator is to cold and is freezing up on 2 shelfs. I had an appliance company tell me it was leaking freon. How could it be to cold if it is leaking freon?"
  • mpcheesman1
    mpcheesman1 May 13, 2010
    Its hard to explain.
    But here goes,Freon in a refrig system is under pressure.Both low and high pressure.
    At a given low pressure, freon will absorb heat from an area to be cooled.This pressure must remain the same to have the freon work or to maintain a given temperature.If you loose freon due to a leak the pressure will be lowe rd resulting in a lower temperature creating ice.Eventually if enough freon leaks out there will be no pressure and no temperature making the refig warm,this depends on the size of the leak.
    Each refrigerator or freezer or home air conditioner is prebuilt and preset for a certain operating pressure.
    Say a refrig with r12 or freon type 12 runs at 32 psig will give a temp of say 35 to 40 degrees f
I have a 601 R sub zero, my veggies are freezing on the shelf above the crisper
Check if Your fridge has ice or moisture on the back wall, behind that drawer, and if service light or vacuum condenser lights are on, if so : you will need to go thru this repair I show on my youtube chanel. Hope It helps. How To Replace Sub Zero Evaporator HD 1080
Jan 04, 2015 | Sub-Zero 601R
My refrigerator has temperature a problem. The top shelf is about 60 degrees and the bottom shelf has ice on back wall and partially freezes food.
open the door,push in the two switches on the top,the lights should go out and the fan on top should be blowing,you can remove the light cover to see the fan,if the fan isn't working cold air will stay at the bottom and the top will be warm.if there's an ice block just on the left side back wall around 2 feet up from the crisper draws then you have a freeon leak in the coil and it has to be changed but it sounds like theair isn't ciculating,bad fan motor.
Mar 05, 2011 | Sub-Zero 690 Side by Side Refrigerator
I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
Here is a link to a Sub Zero Repair Video
http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
Feb 20, 2011 | Sub-Zero Refrigerators
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
I bought my side by side refrigorator years ago and the front door panels are showng spots of rust.I customed ordered this refrigerator and paid 1800.00 Is their anything that can be done about this.
search ebay for "SUB ZERO STAINLESS STEEL REFRIGERATOR PANELS". I sumbled upon these guys one day, and looks like they can make panels for most fridges.
Jan 22, 2010 | Refrigerators
Our sub zero recently started forming ice on the back panel of the lower shelf of the fridge. What do we need to do or what might be causing this problem. Thank you
It's probably low in refrigerant ,that means there's a leak in the seal system .Sub zero refrigerators have 10 years warranty on the seal system you should call them.
Jul 22, 2009 | Refrigerators
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero freezer 600 series - flashing 'vacuum condenser'. I've taken the vents off and cleaned areas, however, the message light does not come off. And the freezer has formed ice on the back walls.
Our is doing the same thing, except we do not have ice forming on the back of the freezer. We were told by a refrigeration repair company that if ice is forming on the back of the freezer then the compressor is bad.
Sep 17, 2008 | Sub-Zero Refrigerators
Sub-Zero 661/F Side by Side Refrigerator Logo
979 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
