Question about Kitchen Ranges
Westinghouse ceiling (natural gas) heater
I have a westinghouse hanging ceiling heater, i have had this heater a long time heating my garage and lust moved to idaho and installed it. my problem is that when it lights there is a small explosion from the heating tubes, I have taken them apart an cleaned all the tubes,and this did not help! the tube holder the gas comes from, Is loose an i can move it up and down? and makes a difference in the expolsions. please help thanks DB in Rigby,id
  • 2,824 Answers
Your igniter may be slow in igniting the gas causing the build up of gas to explode. Should get it checked before you have a fire. Not worth playing with.
Posted on Jun 26, 2017
SOURCE:
  • 73 Answers
SOURCE: oven has small explosion igniting and going off. says tj
A few years back I helped a neighbor with this same problem in a forced air, gas fired, "horizontal" furnace in his attic.
After having him cycle the thermostat a couple dozen times while I watched through the opening in the side of the furnace, I finally figured out what was happening.
First, there were about 6 cast iron burners [about 14 inches long with two rows of gas holes along the length]. These burners were parallel to each other and oriented perpendicular to the long axis of the furnace.
The gas was fed to the ends of the burners with a pipe manifold. The standing pilot light was at the center between burners 3 and 4. Due to the spacing distance between the burners, the pilot light was too far from even burners 3 and 4, the flame could not "jump" to ignite them, or any of the other burners. The manufacturer had installed a thin sheet metal "tent" which ran from the gas entrance end of burner 1 to burner 6, and was about 2 inches above the burner, AND the pilot light.
The standing pilot was on all the time. When the gas control valve turned on, gas began to come out of all the burners at the same time. Naturally it came out of the gas supply manifold ends of all the burners.
The "tent" captured that gas coming from the burners and "filled" up to over the pilot light which ignited the gas at that point, and the flame would propagate along the tent to ignite the gas coming out of all of the burners.
In my neighbors case, the tent had somehow become dislodged so that it did not cover all of the burner ends. For those burners which it did cover [including the pilot light] it caused the burners to light properly.
For those burners who's ends were not covered, and who's gas could not be captured, they would NOT ignite simultaneously with the others.
As these burners WERE feeding gas into the combustion chamber, the gas "envelope" would spread until it reached the nearest flame ignition source, at which time the entire "bubble" of gas would ignite with a minor boom [actually a low energy explosion]. Flame would momentarily shoot out of the burner chamber opening, and from that point the furnace would operate normally until the next restart cycle.
Although there could be several causes, I suspect that the symptoms you describe are the result of DELAYED IGNITION of some or all of the main burners.
IF this is the problem, then the solution is to clean all the burners [including the burner outlet holes in the ignition ends of the burners], clean out the burner compartment, AND properly adjust the orientation of whatever system [you have to evaluate how it works from analysis of YOUR furnace] your furnace has to ensure all burners ignite as close to the same time as possible.
When operating properly, the ignition should be a smooth transition, burner by burner, from the pilot to the farthest burners. In other words. the ignition will "flow" from the pilot outward to each adjacent burner until the farthermost ends ignite last. This usually doesn't take more than one or two seconds at the most.
Unless you are an experienced handyman, and understand this analysis and instructions, I strongly suggest that you engage the services of a professional furnace technician.
Posted on Feb 14, 2009
  • 114 Answers
SOURCE: Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Posted on Apr 28, 2007
SOURCE: GE XL44 Spectra Gas Oven Range
Replace the electric ignitor, I did today... Temps are hotter than ever. $60 from an appliance suplier, easy to install.... Trust me
Posted on Jun 30, 2008
SOURCE: GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Posted on Mar 03, 2009
  • 54 Answers
SOURCE: gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Posted on Mar 22, 2009
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
