I had a paper jam and pulled the paper out - the paper did not tear. Since then the as it completes the startup process up pops a message "A printer error occurred. Please see manual. I have lost my manual so have no idea if the solution is in it. Can you please help?
Lin Just to say the printer is an Epson Photo R340
Lin
AnonymousMay 11, 2008
began with the perennial and continuous low ink warning.
followed by an unacceptance of a perfectly compatible substitue ink cartridge. Then claimed paper jam, and will not stop this. There was a paper jam-months ago. This is a false reading now.
For first problem, I will try to get the download for low ink.began with the perennial and continuous low ink warning.
AnonymousFeb 01, 2009
I have the same problem. Not sure if I need ink or not but the ink will not move back and forth at setup (like it used to), so I cannot even get to it.
You can't post conmments that contain an email address.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
Turn the printer off and on to see if it can automatically clear
some or all of the jam. Many printers provide an error-code listing on
the front panel display for the area where the jam occurred. If your
printer shows an error code, be sure and check the printer manual to
see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If
you find a piece of jammed paper, remove it by holding it with both
hands and pulling firmly (see A). The goal is to keep the paper from
tearing. If several pieces are jammed together, try pulling out the
middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. Thanks! mannu_rakesh
Also open the back cover of the printer if this model has one.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
holding it with both hands and pulling firmly. The goal is to keep the
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
printer back on.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
1. Turn off the printer.
2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Also open the back cover of the printer if this model has one.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
printer back on.
alternative :
Load
try this.... try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
printer back on.
alternative :
Load
printer back on.
alternative :
Load
Step1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step 2 Turn off the printer. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step 6 If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step 7 If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
printer back on.
alternative :
Load
Lin
