Question about Toto Carlyle 1-piece Elongated Bowl Toilet
The chain came off
I can't see where to reattach the chain, as there is no attaching loop visible.
    Scholar:
  • 102 Answers
If your stool has an old style flapper, then the chain would connect to the flush arm at the top and to the little fin on the flapper at the bottom. There should be a little ring connected to the fin. Sometimes the little ring will fall off and go down the drain, then you have to use a peice of wire or whatever you can find. A small clip or something. Hope this helps.
Posted on May 13, 2010
Chain is off On New England grandfather clock, how do I get it back on ?
I've had this same problem with a 30 year old koo koo clock. I'm sure the parts in your grandfather clock are much larger, but the basic design should be the same.
What I had to do was first remove the weight and whatever hook is attached directly to the chain. Then remove any loop or hardware on the opposite end of the same chain. Now, spread open the last link so you can attach it to the first link in the chain. This will make a continuous loop. You'll see why in a bit.
Now comes the tedious part. You'll have to reach inside the clock from the back side with a long piece of stiff wire. Small enough to get underneath the part of the chain that has slipped it's gear. Chances are this chain is wedged between two gears. You may need to bend a small hook at the end of the wire to help dislodge the chain. When the chain is free you can realign it on the appropriate gear. Now that the chain is in the right place, you can advance the chain in the proper direction to get it seated correctly. This is where the loop comes into play. Since the weight was wedged up at the top, you wouldn't be able to advance the chain. Since it's a loop, now you can. Keep pulling the chain in the right direction until you know it's spinning freely. Then you can unloop the chain, reattach the hooks and the weight and test it out.
Hope this helps.
Sep 18, 2014 | Home
Pre-attached chain with loop-hook
Most BBQ makers know that their ignition system will be the first thing to break so they give your a small match holder. The loop holds a short match so you can lower it down to light the burners manually, the chain just connects it to the grill so you don't lose it.
Jan 04, 2014 | Char-Broil Grilling
Chain wont tighten
Pmorrow1975:
When you can't adjust the chain any more, the chain has stretched so far that you will need to remove the chain and replace it, or the tensioner pawl has slipped out of the bar and the chain tensioner will not work. Let's start with the easier solution. First lay the saw on it's left side so the bar is up and you can see two studs with nuts on them. These nuts hold the bar and side cover on. Remove the nuts (a 1/2 inch socket is what you need) and remove the side cover. The side cover holds the chain tensioner. Check to see that when you put the side cover on, the pawl on the chain tensioner fits into the small hole in the bar. If it does not, adjust the chain tensioner screw (below one of the chain retention stud holes in the side cover) until the pawl fits into the hole in the bar, and reinstall the side plate. You'll be able to adjust the chain tension now. If the chain tension is still too loose when the back of the pawl (visible through the slot in the side cover) is at the back of the slot, it is time to replace the chain as it has stretched beyond adjustment parameters.
Hope this helped.
Jul 22, 2012 | Husqvarna 455 Rancher Chainsaw - 20" Bar
Charlesnapostolou@yahoo.comI went to flush my Toto toilet and it would not flush. I took the cover off and discovered that the chain was still attached to the horizontal bar but nothing else. To what do...
There is a piece thats actually called the flapper. It is a rubber flap that has a hing on it and is attached to the bottom of the tank. When you flush, the chain pulls this flap up and allows the water to go out of the tank into the bowl. Attach the chain to the unhinged side of this flapper. Hope this helped.
Mar 01, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
How do i reconnect the chain to the flapper? i can't see a place to connect on the flapper and the chain isn't open on the end link.
You need a new flapper. They are about 5 dollars at home depot it will come with chain already attached.
Nov 30, 2010 | Toto Dartmouth 2pc. E/F Toilet ...
The ceiling fan has a light attached. The chain that operates the light has snapped off. How do I get the chain out to re-attached to the remaining chain
you'll need to turn off the circuit breaker, take off the light kit, it only has 3 screws. Then look for the chain and note where it routes into the fan unit. If there is enough slack you can purchase a replacement chain at any hardware store and should be able to attach it with the little clip, reattach the light kit and turn the power back on
Aug 10, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Is there a trick to attaching the rewind spring to the pulley?
On the end of the spring there would be a loop or some other manner to attach to the pulley. Usually what you have to do it wind the spring tight (not to breaking point) and then put the loop into a slot in the pulley and push down while inserting the screw and washer to hold it in place
Jun 21, 2009 | Homelite Garden
Soap dispenser door came off
First, look at the spring from sliding dispenser cover - it has 2 ends with loops - one end has a little "curve" in it; other end is "straight", no curve.
Sliding cover and lever of dispenser have little knobs for attaching the spring.
The loop of "curved" end has to be pushed and attached to sliding cover,
the loop of "straight" end has to be pushed and attached to lever of dispenser (the lever is blue color, other parts are gray).
After spring is attached to both - sliding cover and lever, push the cover first at upper groove, then at lower groove - It should slide easily.
May 26, 2009 | Gaggenau GI936-760 Dishwasher
Chain
It is used to maually light the burner with a match. The match goes in the "loop" part. It is attached so that it isn't lost/
May 12, 2007 | George Foreman GP324 Stainless Steel Grill
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
491 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
