Question about Simplex Kaba Ilco Unican 1000 keyless lock
Hi there, how do change the lost code on 7104-26d-41 kaba lock?
5 Suggested Answers
  • 963 Answers
SOURCE: Instructions needed for changing the
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: How do I change the
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Customer service can be contacted from this link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good Luck!
  • 963 Answers
Here is the website for Alarm Lock, the manufacturer :
http://www.alarmlock.com/
From here you will find technical documents and a link to customer service for further assistance.
Posted on Nov 09, 2011
  • 963 Answers
SOURCE: i need an instruction to change combo code for Trilogy Alarm Lock T2 TRILOGY
You will find installation and instruction manuals on this web page:
http://www.alarmlock.com/tech_library_instruction_manuals.asp
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 15, 2011
7104-26D-41)lock code change
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Aug 14, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
NEED TO CHANGE LOCK CODE
You will find a link to download the manual for your model on this page:
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Aug 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Need to change lock code on a gun safe
In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Jun 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We have installed a KABA E-PLEX 2000 with several access codes and too many people have aquired the codes. We wish to wipe out all the codes and start fresh. We were given a master code but are unable to...
Programming instructions for your lock can be found here:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jan 11, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
WE HAVE THIS LOCK INSTALLED AND IT HAS THE TYPICAL FACTORY SETTING CODE (2/4 THEN 3). WE DON'T KNOW HOW TO CHANGE IT! HELP
Jan 06, 2011 | Simplex Kaba Ilco Unican LP1000...
How do i change the code if i do not know the former code? also is there avideo shoiing how to do this. FYI i have ythe key that takes the door plate off the inside of the door. thanks tom
I have reviewed the installation instructions and in the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
or (336) 725-1331."
Dec 25, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I tried to change the code on a 1000 series lock and now I can't get any code to work
You have probably inadvertently created a lost combination situation. In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
or (336) 725-1331."
Dec 03, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Lock failure where can i get these repaired cheap.
Nov 19, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
383 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
