Question about Consew 226R-1
I need assistance with a stuck bobbin holder. The owner of the machine says that there is a "reset" button on the machine, but I certainly can't find it. Thanks for your help.
  • 36 Answers
The reset button should be a silver button smaller than a dime on the bed of the machine. if you were looking at the machine as you would while sewing the button would be half way between the needle and the innermost part of the throat. Push and hold the button then turn the main pully backwards it should stop and the turn it forwards and the ball bearing should drop in place. you may have to let go of the button on that one when you start turning it forward.
Posted on May 15, 2010
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
I'm trying to thread my bobbin on my Sears Kenmore sewing machine, Model #158.15160. My bobbin spindle is not turning. What am I doing wrong?
Is there thread stuck on the spindle? If the bobbin is inserted the wrong way, sometimes thread can get stuck on the spindle. Another reason could be that the thread is not pulled all the way through the bobbin holder or it's caught between parts on the holder.
Nov 10, 2014 | Sewing Machines
I just rewound my bobbin and it will not come off the holder, what do I do?
When the bobbin is wound with too much tension it crushes the inside and won't come off the spindle. You need to pull all the thread off the bobbin and replace it. Make sure you wind the bobbin at slow speed and the presser foot is up if you wind through the needle.
Sep 12, 2014 | Husqvarna Rose
Do you need to ol this machine
the manual will probably make no reference to oiling this machine but will recommend cleaning out the bobbin holder with a little brush regularly and getting it serviced by a tech annually. These newer machines have an oiling wick under the bobbin and nylon gears so regular oiling is not so critical. My tech told me that I could still oil into the wick occassionally which I do between services. Certainly if it is sounding noisier than normal then a single drop of quality clear Sewing Machine oil into the middle of the bobbin holder under where the bobbin sits, won't hurt it. The brushing out to remove fibres, threads and dust is important to keep the race area clean so the lubrication can work.
Sep 04, 2011 | Elna 7200 Computerized Sewing Machine
My footup and footdown button is stuck and I keep getting an E1 error on the screen. Do I need to take it in for repair or is there something I can do to fix it? Machine will not sew because of the error...
Turn the machine off first and unplug.
If you've got a manual, look up the page for trouble shooting, this error message may be listed iwth a solution. I'd also suggest that you remove and clean out the bobbin holder. This is the little black piece you put the bobbin into. It has possibly dislodged if you've had a jam up. You will need to unscrew the two screws holding the needle plate down, take out the needle and pressure foot to give yourself some room too. Put the bobbin holder back into position lining up the red markings on the holder and the stopper, your manual should show images of this.
Once its all back together, turn on and hopefully it will reset to normal mode.
If you've done all this and the error message won't stop showing, then yes, you'll need to take it in for a service.
Jul 20, 2011 | Janome Memorycraft 6500P Computerized...
The bobbin seems to be stuck and will not move...all it's doing is 'eating' the thread...what do i do? Thanks
Can you get the bobbin out of the bobbin holder? unplug the machine, then remove the needle plate, needle and pressure foot. Now can you get the bobbin out? It is possible that the bobbin holder has moved in the rotary hook, they can jump sometimes as held in by a magnet.
Check out your manual for instructions to remove the bobbin holder, it should show you how to take it out, and then clean under it, there is possibly thread caught in this area causing the malfunction.
You may find turning the fly wheel a little to turn the hook will help to free up the holder and get it out.
Here is image from my Janome 6500 manual, it should be similar for your MC.
So clean out the underneat of the bobbin holder, then reinsert it, and reassemble, thread and test. If this doens't sort the problem, then time to drive it to the Janome shop.
May 23, 2011 | Janome Memory Craft 9000 Computerized...
I tried to change the bobbin and the machine would not run, so I took it out and now I can't get bobbin out of the holder. It appears to be stuck.
The lever on the front of the bobbin holder locks the bobbin so it does not fall out when you insert the assembly. Do not lift the lever when you try get the bobbin out, it should just fall into your hand. If it does not, look to see if the latch on the lever has not jammed on the bobbin.
Feb 15, 2011 | White Sewing Sewing Machines
Where is the bobbin reset button? I'm working on
May 12, 2010 | Consew 226R-1
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Consew 226R-1 Logo
230 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
