Question about GE Countertop Microwave Oven
No power to unit
The unit does not have power. owned it for a year and 4 months. new. no problems. now it has no power. no lights. breakers are good. tried connecting in another outlet. no power.
  • GE Master
  • 3,740 Answers
What has most likely happened is that somone slowly opened the door when the unit was operating without pusing the stop/pause button first. Doin this will cause the door interlock to blow the internal fuse as it is a design safety interlock to prevent the unit from operation with the door open.
Power plug unplugged
There is a 15A fuse inside the cabinet that must be replaced. Remove the cabinet screws 4 on the side and 6 on the back then slide the cover to the rear about 1/2 inch. Lift the rear of the cover up about 15 to 20 degrees and continue to pull the cover off.
Follow the power cord from where it enters the rear of the unit. The black power wire will terminate at the fuse block. Removed the fuse and replace it with an EXACT type replacement fuse. (buy 2)
If the fuse blows again there is another problem in the unit. If it works normally there is probably nothing to be concerned about. Just make sure that before opening the door you push stop before opening the door.
To re-install the cabinet cover graso the cover from the rear... holding the back of the cover up about 15 - 20 degrees and slide it back into place. Make sure to engage the side locking tabs with the front part of the chassis before installing the mounting screws.
Thanks for using FixYa.
Kelly
Posted on May 13, 2010
I don't have a dedicated circuit for a only microwave oven use only. Is this necessary?
no
microwave ovens are a plug -in unit and be plugged into any socket (GPO outlet) that has the correct voltage for the unit
Jan 04, 2017 | Microwave Ovens
No power
Your stove should be on its own breaker or have its own fuse. Some models of stoves have fuses within their own control panels too. Check your home's panel to see if a breaker has been flipped or a fuse blown, and follow up with the owners manual for your make and model of stove.
Mar 05, 2014 | Magic Chef Microwave Ovens
Tripped breaker while running, now it has no power
You would be better off replacing the microwave oven, it is at the end of life.To replace parts would easily cost more than a new item, plus prices have dropped considerably over the years.
Apr 25, 2012 | Sharp Carousel R530EST Microwave Oven
Our inverter microwave stopped completely and now has no power!
Amanda, If yours is newer construction (less than 40 years) the microwave is likely to have it's own circuit breaker in the electrical panel (in the garage or basement?) so no other lights or outlets might have gone out. I have never seen a microwave that had it's own user-replaceable fuse or circuit breaker.
Feb 10, 2010 | Panasonic MCM INVERTER
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Microwave won't work. The time is frozen, buttons dont work.
I have over 20 years experience with microwaves and over 25 with all other electronics, and I'll have to say it sounds to me also like some kind of power surge "scrambling" its "brains".
Or possibly its power is being interrupted for a fraction of a second and having the same effect.
A microwave should really be on its own circuit breaker.
Microwave ovens, refrigerators, toasters, and electric ovens are very high current devices.
There are power line (mains) surges created when they cycle on and off.
If the microwave can't be on its own breaker, then maybe you can try a power strip with a surge suppressor, or better yet, a power strip with a surge suppressor and a built-in noise filter.
Or it may be that there is a subtle bad connection on the circuit board or at the fuse holder.
These kinds of problems are difficult to diagnose, and even harder to do remotely. Especially since I'm in the US! *grin*
I would strongly suggest that if you can't cure this with a surge strip or similar, please carefully document when and how it fails, then while it is in a failed state, open the door (to keep it from starting on its own) and call Sharp customer service at 1300 13 50 22.
Or you could visit here and click on Service Centre Location search.
You should have a one year warranty, so you should get in touch with a Sharp-authorized repair center.
An over the range type will include home visits in the warranty, but not if it's a counter top model.
You'd have to take that type to the shop yourself, and of course that would mean unplugging it, which would reset it, and the repairman may never see if fail.
If you wait too long, your warranty will be expired, so I'd get in touch with the shop.
Good luck.
Dec 01, 2008 | GE XL1800 1100 Watts Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
GE Countertop Microwave Oven Logo
127 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
