Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not high speed spin. - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 283 Answers
After determining that the motor is running at high RPM and nothing is dragging on the inner basket, check to see that the brake is releasing properly. If not, install clutch kit, p/n 285785 (around $50)
Posted on May 13, 2010
My Frigidaire front load washing machine has stopped high-speed spinning. The regular spin works but not the high spin. Any ideas how to fix that?
Hello Mike, thank you for your post!
From what you have described your Frigidaire washer is not spinning on a high speed. This could be a possible issue with your motor, control panel, or speed board. I would recommend performing a reset on your washer and you can do that by unplugging the washer for at least ten minutes. If that does not correct your issue I would suggest having a professional technician out to perform a proper diagnosis and repair on your washer. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Apr 29, 2015 | Frigidaire Washing Machines
Washing machine wont spin fast
If the motor has a twin speed check the high speed winding. If the washer has a gear box for high speed , check and see if the high speed is initiated while it is on high speed spin.
Feb 05, 2011 | Washing Machines
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 22622 will not shift into high speed during spin cycle leaving clothes very wet every now and then it will go to high speed. i tried turning the dial around a couple of times and it went into high...
Possible overloading or a situation many people do not consider is underloading ,if your machine has an out of balance sensor this will operate in either event and hold the spin to protect your machine .
Nov 03, 2009 | Kenmore 22622 Top Load Washer
Washer will barley agitate or spin and make a
Try high speed only (cycles like cottons, heavy duty, etc. This happens when the low speed on the motor is not working. If high speed is working for you, the olny way to make the lower speeds work is to replace the motor.
Your part number is WH20X10019 and it's expensive...
Oct 20, 2009 | GE WBSR3140DW Top Load Washer
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
My TROMM washer only spins on extra high speed
This washer will automatically choose the fast spin, you can do only spin, don't make the first selection "soil level", just press the spin speed then start.
Is the problem that it is noisy and shaking?
try to level the feet. The installers should have given you a wrench to accomplish that.
Jul 25, 2009 | LG WM-2277HW Front Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
