Question about Canon PIXMA iP1800 InkJet Photo Printer
COLOR CATRIDGE SAYS ITS EMPTY BUT IS NOT. I refill my color catridge for my canon printer ip1980. it has ink now but when i am trying to print, it says still empty!i need help please because I am printing wedding invitations and they need it by weekends. please help!
    New Friend:
  • 58 Answers
Did you mean CL-41 has run out? if so Press Hold the button with orange led on it's side for 5-10 seconds. that will reset your cartridge and the software driver will never monitor the ink cartridge level anymore. Hope to be of help.
Posted on Aug 13, 2010
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Yellow ink isnt printing even after deep clean and test page print
Maybe the ink inside the catridge already low or empty, sometimes each color ink will empty at different time, depend on usage. Fill only the yellow ink and try to print again.
Hope this help and RATE please !
Jan 18, 2011 | Canon BubleJet i965 InkJet Printer
How do you print a document using color ink? I am out of black ink.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with black ink missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with black ink missing even if you aren't using it. That's the case with your Canon printer.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Jan 05, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My Canon Pixma IP1980 print has lines and color is not even, to much green.
I have refilled my canon iP 1980 printer catridges and I am currently encountering 2 problems:
a) The notification telling me that the ink is running low wil not dissapear.
b) There are lines across my documents when I print them. Those lines resemble those that occur when the ink is running out. however, I have already refilled it twice and am quite sure that the catridge is now full.
Please help--your advise will be greatly appreciated.
Jun 09, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My hp printer f4280 display E on the start/copy screen and colore print catridge display empty but i refilled it. printer does not print. what is the problem?
my printer after i refill still shows empty and not printing.please give me the solution i cannot afford to always buy a new cartridge.thank you
Sep 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer still won't work after refilled cartridges
let me know the printer company name..........................
try this............: align your catridges.
wash the both catridges with water & safely rub with soft cloth.
Feb 03, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma refill is not recognized
Dear nedaa,
You need to deactivate ink level detection function to keep your printer working after refilling the cartridge. Click here to know more how to deactivate ink level detection function.
Source:
Canon Inkjet Printer Forum
Canon Manual & Tools Dowload
Jan 17, 2009 | Epson Stylus 2200 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
159 people viewed this question
old marine
old marine
