Question about InFocus LP 600 Multimedia Projector
Colour dispaly problem in LP 640
When we start it shows normal Infocus dispaly with all colour mainly blue when we connect any of the device mainly Computer you will see only yellow mixed green screen.
Without signal it works & shows Infocus logo as ususl when we connect signal then screen appers with yellow
  • 5 more comments
  • ramfromui4v Mar 30, 2008
    The video input from a DVD works alright . Once we connect VGA cable from PC , the problem repeats.. i will try with s video cable from laptop and update in a few mins
    How do we correct the problem with VGA input side in the projector ? is it the problem with the VGA connector in the projector or some circuitry on the board ? how do we find out about this ?? Thanks for your guidance
    Hello thanks
    i could not get an S video cable..
    i tried the vga cable with another projector and it works alright with the same laptop
    i can try S video cable only tomorrow
    can you please advise what could be wrong and how to find what is wrong and whow to correct
    thanks
  • ramfromui4v Apr 01, 2008
    hello
    with S video cable connected from same laptop to projector, the colours are normal and projector works alright
    after this step , removing the s video cable and connecting vga cable to the projector, the problem of only yellow with green color appearance comes back as was the original problem.
    we have changed vga cable and still problem is same .. same vga cable in a different projector works alright..
    Hence problem is with this infocus LP 640 projector only and in the VGA signal section only ..
    can you please help me find out what could have gone wrong and how to correct this ??
    Thanks
  • ramfromui4v Apr 02, 2008
    can i get some help on this ? even though when connected with S video cable , colours are coming alright, looks like there i some clarity loss and blurring leading to un readability of small fonts while in VGA readability is good but comes only in Yellow with green colour
    Thanks for your help ...
    hello
    thanks
    the problem did not get solved with another cable.
    The projector was working normally with any vga cable and has suddenly become bad with yellow and green colour only ..
    now the projector works with S video cable or if we use direct video cables from dvd players , but doe not work properly with VGA cable only..
    hope i have made the problem clearer
    hello
    this is not a new projector , but an old working one which has become mal functioning suddenly with VGA input mode only.
    hope this helps in better understanding
  • 871 Answers
Hey there
when you get the other cable, your problem will be solved. with regards to clarity and blurryness, all of that is on the projectors adjustment.
TRY to check for the pins of the cable or where you insert the cable. as you explain after using another projector, the problem may lie on the pins, however, if you get another calbe which is new and the problem is still there, you shopuld have it check or call there customer support.
thanks for using fixya
Posted on Apr 02, 2008
  • earl norman llanera
    earl norman llanera Apr 02, 2008
    ok,,
    even using a new cable , you still get the same kind of issue right? so in the process of termination... we could say that if the cables are fine... it might be the pins.. if the pins are fine , it must be the outlet behind the projector...if the projector is fine, then it might be video adapter for the cpu itself...
    it may be troublesome to find what is the exact fault... but we can assume that it maight be because fo the drivers to because we are using an old model projector.
    hope this helps too.,...
    Genius:
  • 3,422 Answers
HI,
Just download and go through the user manual from HERE
and refer the troubleshooting steps section.Your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
  • 99 Answers
Try to replace your cable with a good one./try to use onother input of your Projector /refresh the color settings of your projector ./try to change the resolution of your pc.
    Genius:
  • 1,665 Answers
LP600 user guide
Required computer connections
Connect the black end of the computer cable to the Computer 1 connector
on the projector. Connect the blue end to the video port on your computer. If
you are using a desktop computer, you first need to disconnect the monitor
cable from the computer’s video port.
Some Macintosh computers do not have a standard VESA-out video port.
If the supplied computer cable will not connect to your computer, purchase
the appropriate adapter from your Apple reseller.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 02, 2008
    see also page 22 on troubleshooting (Projected colors don’t match sourc)
  • InFocus Master
  • 13,433 Answers
Are you useing SVIDEO out from your pcs video card to connect the image to the projector?
have you set your pc to send video out correctly?
It seems your pc is not sending correct video / settings wrong.
Or then there is a problem with the projector. Try a difrent input?
Posted on Mar 29, 2008
  • Ekse Mar 30, 2008
    tell me how the svideo works
    is your vga cable ok?
  • Ekse Apr 10, 2008
    can you change the resolution in the S-video to compensate for blurrynesS?
Why is my image red tinted on my LP 640 Infocus projector?
could be a bad cable which is the cheapest to try. wiggle the wire at the back of the plug while viewing the picture and see if it changes at all. if it does, the cable is bad. if not, then you probably have a bad lcd cable/connection or a burnt polarizer.
May 24, 2010 | InFocus LP640 Projector Multimedia...
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Infocus 540 has a blue tint to it.
if it only has a blue tint when the computer or video is hooked up, reset the settings to factory default and replace the cables. if the splash screen (when it says "infocus") has the blue tint, one of the light filters are fried due to excessive heat and dust. unfortunately, you'll have to replace the entire optical engine.
Oct 08, 2009 | InFocus LP 540 Multimedia Projector
With all menu settings appearing with their normal values, my X2 projected image ''oscillates'' between showing correct colours and a heavy green overcast with no blues or whites. The green light is steady...
your colorwheel is going bad. needs replacment. find an infocus service center and purchase part # 525-0144-00. shouldn't be more than $50, but replacement is pretty involed. you need to remove the top case, front and back covers, power boards, plate, lamp house assembly, and fans just to get to where the colorwheel is plugged in to the main board. removal of the actual colorwheel is only 3 screws.
Jul 30, 2009 | InFocus Office Equipment & Supplies
REPLACEMENT FOR THE MOTHER OF PEARL COLOURED DIFUSER TYPE GLASS(approx 3cmx6cm) FROM INSIDE THE INFOCUS LP 750 PROJECTOR
unless you find a used projector on ebay, you're out of luck. they don't make parts for that one anymore.
Jul 20, 2009 | InFocus Office Equipment & Supplies
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Quick Start and User's Guide
My infocus projector will not show a you tube video full screen. It is full screen on my desktop...
Nov 29, 2008 | InFocus LP 600 Multimedia Projector
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
LP 640 projector not able to display 1080p
The specs of the LP640 show that the maximum resolution it can handle is 720p. You are trying to make the projector do something it cannot handle
Oct 02, 2007 | InFocus LP640 Projector Multimedia...
InFocus LP 600 Multimedia Projector Logo
96 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
