Question about Gevalia CM-500 12 Cup Coffee Maker
Our office has a Gevalia Deluxe coffeemaker. It
Our office has a Gevalia Deluxe coffeemaker. It brewed one pot of coffee on 5/12/10 and suddenly would not brew a second pot. We unplugged it, clock and buttons still ligh up but nothing happens. Do you have any suggesstions?
  • 3,740 Answers
Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
Thanks for using FixYa.
Kelly
Posted on May 13, 2010
Testimonial: "Thank you."
  • steveclubine Feb 16, 2011
    While not what I wanted t hear, it was exactly the answer was right on target. Thanks.
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Coffee pot turns off after brewing
This is the correct operation for this type of coffeemaker. It uses the thermal carafe to keep the coffee warm after brewing, and doesn't use power to operate a warming plate
Oct 04, 2011 | Mr. Coffee 8 Cup Thermal Carafe...
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Xcc-12 gevalia coffee pot wont brew.
Thermal link open. Located in base of unit mounted against the warming pad heating unit.
Oct 28, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Gevalia xcc-12
clean with limeout, or coffee maker cleaner, I used about 1/2 cup liquid limeout 2 cups water, run through bout 2 times, be sure to run several pots water through after cleaning,
Apr 25, 2009 | Gevalia 50041 / 50443 Coffee Maker
Gevalia #XCC-12 Program Mode
Representatives from Gevalia contacted me and determined the product should be replaced with no cost to me. I expect a new coffeemake within the next week or so. Fantastic customer service - not very common any more.
Jan 11, 2009 | Gevalia 35411 / 50433 Coffee Maker
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
1,078 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
ka4iup
ka4iup
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
