Question about Synology CS-406 (CS406) Network Storage Server
Synology CS406 Unable to Startup Properly
My CS406 is unable to complete the startup process. The power button (blue) keeps blinking and the "status" indicator did not lightup. All other indicators, "Lan" and all 4 HDD, have lighted up.
Please advise what should I do.
Rgds/Ronald
China, Shanghai
Dell Vostro 1014 Laptop Computer is unable to start. how can I fix it?
i have laptop votro 1014 and its giving me problem that while playing oline game my laptop i becoming so slow
Aug 27, 2012 | Dell Vostro 1014 Laptop Computer
I'm unable to start my computer. Everytime I do, I get this blue screen saying a problem's detected and when I click the startup repair, I still get that blue screen again. Help
Startup repair is only meant for fixing software startup issues, mainly programs blocking a startup or registry/startup config errors.
The BSOD or Blue Screen Of Death error is generally aimed at hardware errors. Specifically, it could be your RAM, Hard drive, or any other main component in your computer. The most common is RAM, try replacing your memory sticks and see if it works. Hard drives can cause this error as well when they are on their last legs.
All in all, you may have to re-install windows completely.
May 04, 2011 | Lenovo Elite ThinkPad X200
Iphone not recognized in itunes
Install latest version of Itunes.
1) open "run" from the start menu, and run "services.msc".
2)find "Apple Mobile Device".
3)In the "status" column it will tell you if the process is started or not, and the "startup type" column will tell you if the process will start automatically when windows starts. Set the status to "started" and the startup type to "automatic".
4)To do this right click on this process, and then click on "Properties"
5) In the "general" tab find the "startup type" drop-down arrow menu and make sure "automatic" is selected. Select it if it is not.
6) Also in the general tab check the "service status". If it does not say "started" then click the start button.
7) at the bottom of the properties window click "apply"
Jan 25, 2011 | Apple iPhone 3G
When i plug it in with out anything plugged into it it automatically starts blinking select green lights is there anything i can do to fix this?
The all lights will starts blinking everytime the switch is powered ON.
This is normal process as the switch is checking the status of all its ports during startup.
Please wait for 5-10 minutes this activity will completed and the port lights will not blink if nothing is connected.
If it still blinks without anything connected to the ports then you need to ask the vendor for a replacement.
Jan 08, 2011 | NetGear ProSafe JGS524 (DHJGS524NA)
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
My defrag program says it is unable to gain access to selected drive. It says another process may have the drive locked???
you need to close all open programs and reboot before you defrag
if you want a clean reboot go to start remove all programs from the startup file so nothing is in the background, if McAfee is in your start up file, it will prevent you from a complete defrag
start/all programs/startup click and drag each file in the startup back to all programs and then do a new reboot
May 11, 2009 | Computers & Internet
Rewaking my toshiba laptop
hold down the ALT CTRL DEL Key If that don't work hold esc for 5 seconds or hold down the power button for 10 seconds
Sep 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Google end user licence agreement
To stop the problem completely, you need to go to 'Task Manager' then 'Processes' click EULA.exe then 'right click' and click 'Open File Location' do that with all EULA.exe and go to the open folder and delete all the files associated with it or delete all you see on that folder. Restart window afterwards and you will see the problem is gone.
Aug 19, 2008 | Computers & Internet
Synology CS-406 (CS406) Network Storage Server Logo
56 people viewed this question
Top Synology Computers & Internet Experts
David Payne
David Payne
Are you a Synology Computer and Internet Expert? Answer questions, earn points and help others
