Question about Philips Televison & Video
I have a philips lc4.3e Hd ready tv and want to know how I can connect a laptop to it and also how to get HD tv on it
5 Suggested Answers
  • 1894 Answers
SOURCE: Illegal Signal DVI/RB 3
see this link...here is the user manual....
Posted on Mar 01, 2008
localwonder
  • 6784 Answers
SOURCE: dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Posted on Jun 21, 2009
  • 2385 Answers
SOURCE: is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Posted on Jan 03, 2011
  • 141 Answers
SOURCE: Connecting Ps3 with philips tv
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
Posted on May 04, 2011
Idk if my tv is digtal ready it says its hd
The TV will provide an HD picture with a set top box connected to the HD input (AV4 or AV5). It does not have a digital tuner (only a NTSC analog tuner).
The manual is available here: http://download.p4c.philips.com/files/5/51pw9303/51pw9303_dfu_aen.pdf . See appendix B on page 58 for the specifications.
I hope this helps.
Apr 19, 2011 | Philips 51PW9303 51" Rear Projection...
I need to know how to switch the TV to 1080. I'm trying to use a HD box
Connect you hd cable box to the hdmi input. If you don't have an hdmi input and have a DTV input you can get an HDMI to DTV adaptor. I hope this helps.
Mar 20, 2011 | Philips 60PP9202 60" Rear Projection...
When i connect my my hd cables on my philips 32fd9954 tv the sound will not work
It is likely you are connecting via the DVI or VGA connectors. By default, these do not carry audio. You will need to bring audio into the display through one of the other sets of connections, then manually select the input with the remote.
Sep 30, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Brought a logic hd ready tv yesterday but can't
You will still need a HD box connected to the TV to send a Hi Def signal to the Televisions display, A la HD "ready" TV's. I know I had my 1st for over a year before ever seeing even 720 let alone 1080 ><.
Oct 04, 2009 | Televison & Video
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
I want HD tv
No. Your tv is not hd. If it was you would know about it, because you would have forked out quite a lot more money for the priviledge, and it would have been a major selling point of the tv.
Feb 01, 2008 | Televison & Video
Philips 42PF9946 upgrade
i am wondering the same thing. the tv is great but i dont want to change it but i want to get hd...
can anyone help
Jan 03, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
How to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
Oct 20, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
