Question about Orion FTDV2004 20 in. TV/VCR/DVD Combo
VHS The VHS player plays sound, but not the picture. When I fast forward, I can see the picture.
  • 97 Answers
Maybe it is a default, ocnsult the manufacturer
Posted on Jul 15, 2008
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
No vhs picture.
I HAVE ONE OF THEM TRY HITTING YOUR "TV/VIDEO" BUTTON
Jan 11, 2009 | Panasonic DMR-E75V DVD Player/VCR
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
VHS picture won't work but DVD is fine
VHS part of your machine got video head dirty / clogged. use good quality VHS head cleaning cassette to see picture again.
Sep 30, 2008 | Philips Magnavox DVD/VCR Dual Player
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 18, 2007 | Funai PY90VG DVD Player/VCR
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Orion FTDV2004 20 in. TV/VCR/DVD Combo Logo
63 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
