Question about Fuji FinePix A820 Digital Camera
Computer says can't launch Finepix driver because
Finepix S200 plugged in to USB but Computer says can't launch Finepix driver because of code 19 problem
    Brigadier General:
  • 11,967 Answers
Use a card reader instead of the camera.
Posted on May 13, 2010
Usb drivers for finepix av 200
Do you really want a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 07, 2012 | Fuji Cameras
How do i download picture from camera to computer and print
Plug the USB connector into the camera and the PC
The “Found New Hardware” help message should appear in the bottom-right corner of your screen.
This message will close when the settings are completed. No action is required.
This step is not required for subsequent connections.
Specify the settings in the “AutoPlay” dialog box.
When FinePixViewer is included in the list of actions to perform
Select “Viewing images using FinePixViewer” and then select the “Always do the selected ction” checkbox. (This checkbox may not be shown in some cases.)
Click the [OK] button to launch FinePixViewer.
When the camera and computer are exchanging
data, the self-timer lamp blinks and the viewfinder
lamp blinks alternately green and orange.
“≥” appears on the LCD monitor.
Power Save and Auto Power Off are disabled during USB connection.
Do not disconnect the USB cable when the camera is communicating with the PC.
If the above operations do not occur, you do not have the required software programs or drivers installed on your PC. Complete the required PC setup procedures. Then reconnect the camera to your PC.
Switch your PC on.
Use the USB cable (included) to connect the camera to your computer.
Switch the camera on.
Take care to ensure that the included USB cable is connected the correct way around and that the plugs are pushed fully into the connection sockets.
And if this wasn't clear enough, here is the user manual for you.
http://www.fujifilmusa.com/shared/bin/A210_A205Manuals.pdf
I hope this helps and good luck!
Nov 04, 2009 | Fuji FinePix A205 Digital Camera
When i add mp3 songshangs my computer
does your muvo s200 able to turn on?
if not the circuitry in your muvo s200 is deeply damage
your computers hanging because of the possibility that the circuitry of your muvo s200 is short circuit which may damage your computer also specially the usb ports...
or try to plug it in other computer if it works
hope this will do
please vote....
Jul 08, 2009 | Creative Labs MuVo S200 MP3 Player
I have a macbook and i connect the usb cable to upload my photos, but the usb is not recognized do i need to download any software. Its says that mac autmatically recognized the camara
the Mac normally recognizes the camera and launches iPhoto.
Try launching iPhoto, then plug in the usb cable. Make sure the connections are tight on the camera end of the cable.
Apr 22, 2009 | Fuji Finepix Z20fd Digital Camera
Nikon CoolPix S200 SHUTS OFF when usb plugged in
Did you install the drivers to the computer? And install the nikon software to your computer? If you didn't that is probably your problem. Otherwise you can get a cardreader and use it to get your photos on you computer.
Jan 07, 2009 | Nikon COOLPIX S200 Digital Camera
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Driver needed for Nikon coolpix S200
You need the Win 98 USB driver- Google for that.
Dec 16, 2007 | Nikon COOLPIX S200 Digital Camera
Finepix a600 not recognized
Remove the camera software entirely. Assuming you PC is 2000/XP no camera software or driver is required. It should simply come up as a new drive in My Computer Come back on this one
Jul 12, 2007 | Fuji FinePix S304 Digital Camera
Fuji FinePix A820 Digital Camera Logo
97 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
