Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
I have a code 5. I replaced the flyback x-former for no dc volts,now it seems it`s too high at 1150vdc.TV flashes and goes off,tried to turn down the screen setting very little decrease in the volts.please help
  • Sony Master
  • 12,061 Answers
Http://www.nodevice.com/manual/sonymans/manual3581pdf/get5097.html
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
http://s100-manuals.com/manualdetails.asp?id=126730 http://www.s100-manuals.com/manualdetails.asp?id=363935
Hi, well I applaud you for wanting to have a go and try to repair you set. But PLEASE, start in the right place, otherwise you will simply waste your time and money, You see, you MUST start, in the right place, The power supply, FIRST, as, if, that isn't right, nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now, also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" and replace them, because someone else had done so and it worked, well that maybe sometimes true, but most Symptoms, can, and do have many, many different "Causes" & also, now while that may be true in a few cases, a faulty Electrolytic Cap, or even, ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
http://search.agoraquest.com/searchbb.php?term=KV-40XBR800&addterms=all&forum=all&submit=1&sortby=p.post_time
www.scribd.com/.../Sony-Chassis-AA2W-TV-Wega-Training-Manual - 6 hours ago -
www.scribd.com/.../Sony-Training-Manual-TV-KV32XBR400-Chasis-DX1A
Above are two training manuals,above those, is a link, for a forim, discussing your set, above that are two pay for service manual link, above that are Sony Blink fault codes, above that is a user manual, with these you should be able to sort out your problem, ALL links have great info.
Posted on May 13, 2010
My sony kp- fx532m91 has trouble in turning on it takes 30 to 60 minutes before it will open/on. and it blinks six time every 3seconds. what could be a possible remedy anyone can help me.
Iam thinking that 6 blinks means power suply make sure all voltages are right according to the board.Could be somthing is pulling down on 5 volt line or12 volt line. If it is a CRT which Iam sure it is then there is 150 volts DC or so for the flyback there is a high voltage block for the high voltage for each gun red blue and green.Check power suply horizontal output high voltage block focus and screen block.
Nov 21, 2013 | Televison & Video
Lights flash then powers down.
Before read this, keep in mind that this is not your model and parts are not the same. This is just to let you know the steps to take. Sorry don't have the schematic for your set, but maybe this will help in checking. I'm Ex-Army myself and Veteran of OIF and OEF.::::1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
Aug 25, 2007 | RCA HD50LPW175 50" HDTV
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Replaced a convergance chip..(ps8003) now tv
hello Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
regards
shaun
Feb 24, 2010 | Sony KP-46WT500 46" Rear Projection...
Won't turn on
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
Nov 15, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
AR-207 copier has "CH" flashing what to do?
CH code is usually associated with the Crum chip located on the back of the toner cartridge that gets 5 volts dc from the power supply and resets a counter on the main board to tell the copier approximatley how much toner you have when you insert an new toner. What may have happened, is the same 5 volts dc is shared with the laser unit and the when the laser goes bad it may cause the CH code just before it gives the E7-03 code for the laser due to the 5 volts being drawn down by the bad laser. If turning the machine off and back on with the new toner doesn't fix it then you either have a bad chip on the new toner or a bad LSU (laser Scanner unit)
Please don't forget to rate our answers please.
Dec 14, 2007 | Sharp AR-207 Copier
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Sony Wega 42" LCD HDTV
I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
Thanks
Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
