Question about Cameras
HELP! dropped camera, lens won't go back in, shutter won't close
So someone dropped my baby, my camera lol, and the lens won't go in. AT ALL. The shutter will not close either. When I press the ON button - the screen is blurred - i can hear the shutter trying to open - the sound for the start up goes a few seconds later - it turns off Please help. This camera cost a lot and I really need to have this sorted ASAP. i have the same problem. my digital camera was on a chair and someone bumped into it...it fell...omg! haha. but now the lens wont go back in and when i turn it on. it beeps three times pauses and beeps twice then turns off. the screen doesnt even show anything. ahhh!!! help! ...oh and btw.. its now MY camera... =S its the kind of camera you get at target for about $100... i couldnt figure out how to find what model or w/e it was so ...idk. it is the green one.. if that helps =P
  • Anonymous Jun 28, 2008
    ok well i dropped my camera in the sea...BUT it is working now it takes pictures and turns on (as long as i dont leave the battery in too long - this is another problem) but the shutter wont close when i turn the camera off. I thought it could be dirt but i've tried cleaning it is there anything i can buy to help me with this?
  • katerlicious Mar 21, 2009
    My sister dropped my camera (Samsung S800) on the floor. The lens won't close (go back in and turn off). When I turn it on, the screen comes on blurry, then camera beeps threes times (different sound than when battery low), then shuts off. How can I fix this?
  • Cameras Master
  • 6,079 Answers
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Posted on Mar 15, 2017
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: HELP! dropped camera, lens won't go back in, shutter won't close
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
Posted on Jul 26, 2008
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
When pressing the power button, the shutter opens, the lens comes out, the screen comes on for about 2 seconds. Then the screen turns off, the lens goes back in, but the shutter stays open. I let someone...
Look closely for sand particles that may be lodged around the gaps of the lens barrel. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Panasonic Lumix DMC-TZ3 shutter doesn't close all the way and gives message "please turn camera off then on again"
My camera got dropped into the dirt. The dirt grains are detrimental to the plastic mechanics of the lens system, they imbed themselves into the plastic and become like sand paper. I took my whole camera apart - something that I would not recommend but I was desparate. I don't think I can save my camera, it needs a new optics.
If the shutter has problems it is most likely that the thin aluminum casing at the front of the lens got bent and you may be able to bend it back with a thin screw driver, that you can manage to insert between the plastic casing of the shutter and the aluminum cover. Just where the aluminum casing ends at the front of the lens. But be careful, you may otherwise damage the aluminum and the looks of your camera. If you got dirt in there, you may want to manually (carefully) open the shutter when the camera is shut off, let it close, etc. while blowing air between the gaps of the shutter blades. You can buy a 'Cleaning Duster' spray bottle from Office Depot and use that. But be carefull to hold the bottle straight, don't tilt it or the liquid content will spray over your lens and you have to clean the oily residue with a solution of soap and water (I had to) and wet a paper tissue (use a Kleenex that is not impregnated with a lotion, on the back of the box it will tell you 'Not recommended for cleanig eyeglasses'.
Hope that helps.
Stephan
If that doesn't work, then you may have to send the camera in for repair.
Aug 30, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Tapp the lense GENTLY in the opposite direction of the misalignment
Nov 25, 2007 | Kodak EasyShare DX6490 Digital Camera
Sep 24, 2007 | HP Photosmart R927 Digital Camera
Will turn on, then beeps 3times & turn off in 5 seconds w/ the shutter still out
I had this same problem and it was driving me crazy. I looked the camera over carefully and noticed that the lens was a little crooked. I gently pulled the protruding lens piece a little and it popped into place. After that, the camera worked fine. I guess if the lens is jammed the camera won't turn on if the lens can't move. I hope this helps you.
Sep 04, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
1,082 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
