Question about Kenmore Refrigerators
I have a Kenmore side by side model #106.50517001. It started defrosting and not coming back on at odd times, I thought that it was probably the defrost timer, you could unplug the fridge, plug it back in and it would start working but when you turned the timer screw, it would go off then not come back on. I replaced the timer and it still wasn't working. Out of frustration I slapped the control panel cover and it came on. What else inside there do I need to replace?
  • hosskix May 16, 2010
    You were correct, it was the thermostat, I replaced it and the fridge is cycling like it should now.
    Thanks a lot!
    President:
  • 2,468 Answers
Replace the cold control that operates the compressor it is located on or near the control panel
Posted on May 13, 2010
  • hosskix May 13, 2010
    Thanks for the quick reply, I'll give that a try!
  • danny Hendrickson May 13, 2010
    you can bypass the cold control before you purchase a replacement by jumper wiring around the control,if it runs then its the control,please rate this if it helps you in your query
Kemore Elite Model #106.74902401 Freezer is working although frost is forming , the refridgerator is not cooling properly and the side fans are not coming on . It isn't making any odd sounds .
In your refrigerators case I believe the Click Here=> 10674902401 Kenmore Refrigerator Parts in that photo you may need to click to enlarge depending on what type computer you use. Item number 4 is=> 2304146 Control Board this is a defrost control board found behind the controls just above the top shelf inside your fresh food section and behind the controls. Many times you may find burn marks that indicate that the board is defective. Always disconnect power to refrigerator before working with electrical parts. This is the most likely cause for your refrigerator not defrosting but only the first thing of three parts to examine. Click here=> Here you will see item Whirlpool Bi Metal and Defrost Components Photo behind the rear panel of your freezer rear panel. The defrost Thermostat is=> 4387503 Defrost Thermostat and=> 2315531 Defrost Heater Assembly To make things simple begin by looking over the Defrost Control Board first. Ask me questions and I will help you should you have any questions, Thanks, Sea Breeze
Jul 13, 2011 | Kenmore Top Freezer Refrigerator
I have a Kenmore model#363.50242000.Its a side by side, every couple of weeks, the back wall on the freezer side gets a coat of ice and the temp start to increase. I have to manually defrost it overnite to...
Hang in there I just may have the solution. There are 3 major components of your defrost system. Behind that rear wall is your defrost heater and defrost heater part=> WR51X10031
Te most likely problem is the defrost timer=> WR9X489_defrost_control and here is where heater and defrost thermostat are located=> 363.50242000 Freezer Section First you need to look inside your fresh food compartment and Click Here=> Control Panel just behind that panel is a defrost timer see if we can force defrost by using a flathead screwdriver slowly clockwise until the compressor and fans stops then after about a minute defrost will begin and after 25 minutes the timer should turn the refrigerator and fans back on. If not replace timer if yes the come on and still no defrost the we need to go into the freezer and replace the defrost heater and defrost thermostat, please rate this solution, Thanks, Sea Breeze
Mar 12, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side fridge model #:596.58695890
The defrost heaters are bad. Take the inside back panel out. Take a hair dryer and defrost the back where you took the panel off. You will find a set of coils under the ice. Inside those coils there will be a heater. Either one made of the same thing oven elements are made of or they will be glass with a coil running through it. You can inspect them and most of the time you will be able to see either the glass broken or the coil inside the glass. Or if it's made out of what a ovens is made of you will see where it is burned into. After defrosting, you can put the panel back in and turn the fridge back on. It will work normaly for around three days before it starts frosting back up. This will save your food and give you enough time to either get the part to fix or have someone to come out to fix. Word of advice. If you have someone to fix it, be sure to defrost it at least 24hrs befroe they come because it's iced up they will have to defrost it and as you will see. It takes time and they will charge you by the hour to do it. Good luck
Please rate this solution. Thanks
Aug 19, 2009 | Kenmore Refrigerators
My freezer cools properly but my refrigerator is not staying cool .its kenmore and bought from sears 2004 $1000. side by side refrigerator
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace this part for a permanent fix - also advisable to swap out the defrost timer at same time
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Kenmore side by side not starting after defrost.
Probably has a defective defrost control from what you are describing.
Dec 17, 2008 | Whirlpool 21.8 cu. ft. Side-By-Side...
Side by side kenmore refrigerator not cooling.Tampa FL.
HI thanks for your question. the problem you are having is that its not going into the defrost cycle. its not an expensive repair, probably $ 150. 00. unless you have the proper meter to check i would call a tech . but its more likely the defrost timer. or the defrost thermostat. thanks the appliance doc. please rate my answer. thanks.
Oct 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Side by Side defrost Issue
well tia i need the model number so i can guide more to wich part is failing but if you want repl the timer and defrost thersmotat you can repl all parts under 200 dollars versus 1500 for a new refrigerator is worth fixing it
Oct 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator not working
you have a defrost problem a tech will charge you between 100 to 200 to fix it unles you do a little research and repl the timer and bimetal but i will lean more to the bimetal that controls the heater but definetly is defrost issue easy fix but if you dont know how my number is on the tech list
Oct 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 1067667461 light on but takes forever motor turn back on??
 Providing your model does not have a digital temperature circuit board, the defrost timer likely is bad. I tried to look your model up and had a problem because I think the make and model is listed incorrectly above your post..
The defrost timer should be near the interior light behind plastic. In the plastic is a plug or a small opening the size of a pencil in diameter. When it stops again turn the black screw about an 1/8 of turn clockwise. If the compressor comes back on the defrost timer will need replaced. If it does not help, try to find the exact model number listed somewhere on the fridge, most times behind and lower right hand corner with the door open, hope this helps, Thanks Sea Breeze
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
