Sharp SF-2540 FI-06 error code
Can anyone tell me what this code is and how to reset it or fix the problem. also looking for a service manual for this copier thanks Dana
  • 146 Answers
Looks like a shift error. This is the part that offsets the pages at the exit. See below.
Posted on Jun 06, 2008
My sharp SF-2540 it has a code H5-02
its an error code for the fusing unit
Sep 06, 2016 | Sharp SF 2540 Copier
How do i remove error code C2 on Sharpf SF2540
Check the Transfer corona wire assy. located under the drum where the paper flows by, mite be broken or the power supply that provide power to it mite be bad, several hundred to thousand of volts during a copy operation when machine is woking
Sep 22, 2014 | Sharp SF 2540 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How can I reset the password/ Copying code on SF 2540 copier
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Sharp SF 2540 Copier
Call for service
What is the error code that is being displayed???
Sep 09, 2011 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Error for sharp SF 2540 H4
H4 means; Heat roller low temperature detection. This is an error in your fuser and you will likely need to get a service technician to take a look at your copier.
Sep 15, 2010 | Toshiba e-Studio65 Copier
ERROR H5-01
H5-01 means that you have 5 continous paper jamm in the machine. Try to rest by pressing C INTERUPT 0 INTERUPT 14 START.
If problem still occur, check the paper detection sensor by pressing C INTERUPT 0 INTERUPT 30 START 1 START. and manually activate the sensors and look at the display.
May 27, 2009 | Sharp SF 2540 Copier
Sharp SF-2540 copier error code FI-06
The F1-06 error is = Paper exit drive overloaded in sorter. This means that the exit unit is not driving/ turning properly/ fast enough. This could be that the motor is going bad, exit sensor is bad, drive belt is bad, paper or forgn. ( staple, paperclip, .ect...) in stuck in that area. If you do not have the proper wall voltage, could cause this problem.
Check wall voltage, check exit area for torn paper, paper clip, etc..., check exit sensor and actuator, check belt for wear or broken, check motor ( is it turning/ running) and then controller brd.
Mar 29, 2008 | Toshiba e-Studio65 Copier
Sharp sf.2540
Press C - interrupt - 0 - interrupt - flash
and then
14 and press start
Feb 26, 2008 | Toshiba e-Studio65 Copier
128 people viewed this question
jasbo
jasbo
