Question about Microsoft Xbox 360 Console
Freezes,and red lights come on
Freezesand red lights come on
    Genius:
  • 1,234 Answers
Hello Sir =)
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shad0w
Posted on Aug 27, 2010
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Mar 22, 2013 | Frigidaire Freezers
Games freeze. red light flashes when i turn on
see if youre disk is cracked in the circle and make sure all the cords are plugged
May 02, 2009 | Microsoft Xbox 360 Arcade
Xbox freezing constantly
You can check out the articleatezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369formoreinformation on fixing freezing problem of your xbox 360
Jan 01, 2009 | Microsoft Xbox 360 Console
Red light
The modem doesn't really have anything to do with the 360, it's a separate issue. If the console is freezing and giving you red lights then that's different altogether, please explain with a little more detail and I'll try to help you further!
Nov 28, 2007 | Microsoft Xbox 360 Console
Freezing
Same problem as the 3 red light error in most cases. As far as freezing.
One red light is different. Check the error codes here.
Nov 06, 2007 | Microsoft Xbox 360 Console
Game freezes after 5-10 mins play time
if when it freezes it has a kind of checkerboard pattern, then it is what happens before the three red lights of death, try the eraser trick posted by Carl26
Aug 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
