Error message E11 - Washing Machines
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 4 Answers
STOP the insanity....that's what you're saying if you encounter the F11 and/or fDL error codes on your washer. If you're not there yet, you will be soon....
The dreaded F11 and/or fDL codes - been there done ALL that!! Our Whirlpool DUET washer is just over 5 years. We experienced our first F11 code 6 months ago (warranty just expired what else is new?). When it first happened, I thought nothing of it - hit the cancel button and the machine reset itself. Then it happened again and again and again. Each time it happened it was more challenging to reset it. I searched for the fix on line - I should have done my research before we purchased the washer.
I was able to determine the error was stemming from the CCU board. Order a new one at over $300.00 and have the same thing happen again - I don't think so. We tried EVERYTHING suggested on multiple websites.....unplugging the washer, hitting the right upper side, checking wires, wiggling the wires, wedging things to improve contacts, soldering, re-soldering, Vaseline, changed relays....anything and everything was a temporary fix. Contact Whirlpool directly? Tried that too, they apparently don't recognize there is an issue with F11 fDL errors, "not a commonly called in concern". Really?? We started searching washers to purchase....I couldn't bare spending $$$ for another washer, but we are a busy active family with 4 kids - what are our options? Then one night after searching the websites for one last desperate attempt at salvaging our washer, I followed through on a link:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
email: selling.surplus@gmail.com
Now, I'm the biggest sceptic in the world and the most frugal consumer - really I am. I am posting my testament to this service because I've been there - frustrated, disappointed, angry. I am so pleased with the service Ed provided - from answering all my questions, to the superb job he did on the CCU. You can review all the comments posted by all his other pleased customers on eBay. I had to stand by my washer for the first 6 loads - just in case the beep beep beeps started. To my astonishment, amazement, and surprise - it never happened!! In my opinion, this is the only true fix for your F11/Fdl error!!
I never imagined in my wildest dreams ever telling anyone how happy I am to be doing my laundry again, but I really am!!
Posted on May 14, 2010
2 Suggested Answers
  • 22 Answers
SOURCE: On my Haier HWD1000, I keep getting error message
Error E11 means either:
The water level can not
reach the reset water level
within 5 minutes
OR
reach the setting water level
within 8 minutes
What this means is check your water supply for sufficient pressure and if for some reason it stops and starts (eg. well drawn water with a small reservoir sometimes.)
You may have to make sure that there are no other water uses going on at the same time.
Posted on Aug 12, 2010
It freezes on the cycles
Good Morning Juan,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000E, freezing on the cycles and giving you an Error message 11. The E11 states that fill time is too long. There are a couple of things to check in this case. First, you will want to reset your appliance by either unplugging it or cutting the power at the circuit breaker for at least 2-3 minutes. When you restore power you can start a cycle and see if it works. If it does, there just might have been some miscommunication between the different boards inside the washer. If it is still giving you the E11, you will want to make sure that the water pressure is at least 30 PSI. Make sure you're not using any other water sources while using the washer. Also make sure that the faucets are fully opened going into the appliance and that the hoses are not kinked in any way. If you are still having trouble receiving that E11, I suggest contacting the manufacturer for further assistance. Hope this has helped.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire Affinity ATF7000E Front Load...
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
E11 error code fios motorola box
Eb 11 - Invalid unit address / Resettable only at factory / Replace the DCT
Here's a site with a list of fault codes:
How to use Motorola DVR Boot Error Codes
Mar 31, 2012 | Motorola Televison & Video
My washing is saying error 2
E11 is low water pressure
E12 is a slow drainage problem
E13 too much water
E31 motor problems
U02 is cannot lock the door after 20 seconds
E22 is memory failure
what exactly does the error message come up with and when does it occur
Feb 24, 2011 | Haier HWD1000
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN RICOH 4018 AND E11 ERROR MESSAGE IN RICOH 4622 PHOTOCOPIER
e 5** fuser related temperature over/under
e1** optics related
both need service engineer
Oct 04, 2010 | Ricoh Office Equipment & Supplies
On my Haier HWD1000, I keep getting error message E11... what does this mean?
within 5 minutes
OR
within 8 minutes
Jun 21, 2010 | Haier HWD1000
E11 error. I purchased this camera used and can not get the camera to start. A indicator lite flashes green for a few seconds then red/yellow and shuts down. I have removed the flash memory card and...
Error Code "E11" on Kodak Digital camera means that the battery needs replacement. If replacing the camera recommended battery AA 1.5 volt alkaline or AA 1.2 Ni-MH rechargeable battery still error "E11" the camera needed to be service.
Nov 20, 2009 | Kodak DC290 Zoom Digital Camera
My ford ka has a cd stuck in it with error code e11 showing. Help?
According to the Ford Audio Guide error E11 is "SPI BUS FAILURE" and Ford recommend "Check and repair the wiring harness "
I suspect that the error message will be because of the jammed CD.
You can possibly tease the CD out through the slot  using another (old) CD.
Failing that , remove the player from the dashboard, take off the cover and release the jammed CD
Make sure you have the Security Code before pulling it out of the dashboard
Sep 03, 2009 | Car Audio & Video
Washing Machines Logo
644 people viewed this question
Top Washing Machines Experts
