Question about Air Tools & Compressors
Model Number BECP200....won't start...already checked the fuse..maybe 10 hours of use
  • 374 Answers
Hi there, if you've checked fuse on the main switch and other circuit is good checke the pressure switch and it's contactor inside use tester if necessary to check continuity resistance if its good,otherwise if defective replace pressure switch.on large compressor this was equipped by overload protection relay have it reset.have a nice nice day.fix my rate.thank you very much.
Posted on May 14, 2010
My 99 jeep grand cherokee was t-boned at 10 miles per hr now it won"t start,is it a ignition fuse,or damaged ecm ?
If she hit you hard enough it could have tripped the rolloversswitch in the passenger side kickpanel
Feb 07, 2014 | Jeep Cherokee Cars & Trucks
Stat button
see this steps and fix it. GOD BLESS YOU
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jul 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Car won't start.
Check fuse for fuel pump fuel pump relay and computer fuse in fuse block use maybe mark EC M 1 or 2
Mar 26, 2013 | 1996 Chevrolet S-10 Pickup
I have a 2005 scionxb an dit won't always start. It doesn't make any noise when you turn the key. The battery is fine. The radio will not come on but the windows work.
There might be a ground wire loose or any of the positive wires coming off the battery might also be loose or coroded. That can also be part of your prior fuse problem. If its the same fuse that blows, that could be where your entire problem existes.
Jan 31, 2013 | 2005 Scion xB
Truck won't start after replacing the fuel pump and filter?
maybe that was not the problem in the first place or you might have a blown fuse, was the old sender burnt, check fuses and make sure it is plugged in correctly
Jan 15, 2013 | 2003 Chevrolet S-10
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 | Vacuums
a lot of motors have a red reset button on the **** end, try pushing that, if that doesn't work try to manually rotate the pulleys/belts to make sure the unit isn't locked up. let us know if this helps
Mar 19, 2010 | Black & Decker Air Tools & Compressors
Samsung fridge freezer model number srs615dp. The temperature displays -16 and 3 degrees. After approx 10 hours the display flashes. Turn off the power and on again and it displays 4 and 14 degrees and...
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Jul 04, 2008 | Frigidaire FRT18B4A Top Freezer...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
