Question about Crown CE2000 2-Channel Amplifier
I am having a problem with my crown k2. As soon as I flip it on the lights go up but then click and it shuts down. No enable light on. I have to unplug it for a bit to get it to do the same thing again. This is with no load on it at all.
  • 3 Answers
Most likely the thermal protection device is tripping due to a short circuit. Under a no load condition this is usually caused by one of the power amplifier transistors being shorted internally or a bypass capacitor shorting internally. One would have to test the components to determine the source of the failure.
Posted on Sep 11, 2010
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
94 CROWN VIC/ OVERHEAD LIGHT WORKS SPORADICALLY
1) you must connect the switch in series, in tha way you will not have this problem, and you must add of course the relais, for to avoid the spark, and arching by load .Now you have connected in paralell.
God bless you
Jun 27, 2012 | Ford Crown Victoria Cars & Trucks
I have a crown k2 amp that I think Have have fed bad signal, a result of having a pet chew through some of the input and output cables. Immediately, it showed erratic warning light displays, and the audio...
Check the gain control in front panel. The material use inside them is pretty thin and weak, an could break loose when hurting during manipulation.
Spider Guy
Mar 13, 2010 | Crown CE2000 2-Channel Amplifier
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
I have a Canon ESO Rebel K2 camera and my low battery light comes
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Aug 10, 2009 | Canon EOS Rebel K2 35mm SLR Camera
1988 Ford Crown Vic Strange Idle (Getting Worse)
i am trying to install an aftermarket temperature guage with capillary tube into my 1988 crown victoria ltd 5.0 efi. where does the capillary tube mount?
Jun 27, 2009 | 1988 Ford Crown Victoria
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Crown CE2000 2-Channel Amplifier Logo
176 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
