Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
My SONY Trinatron is starting to "blink", i.e., quickly pulse to a black screen. Each blink is about a second in duration. These episodes seem to vary from two or three blinks to as many as dozen. It has been doing this for over a month. At first, it did it for a few minutes when we turned it on. Lately it does it periodically even when the TV is warm. When it does this, we do not lose sound. We haven't moved the TV, so I do not suspect a wiring problem. I fear a more serious (expensive) problem. It is close to ten years old. Is this the end? Please advise. Thanks, John B
  • 321 Answers
That is a capcitor near protection relay or a regulator
for 135 volt call str or the horizontal driver out put for the highvoltage. watcht theres is very high voltage in there.disconnect for a while before opennig the case IF YOU DONT HAVE EXPERIENCE CALL A TECHNICIEN !!!! and for me the price to fix it is about an hour time plus parts
hope that will help
regards. Alan
Posted on May 13, 2010
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
My sony tv has sound but no picture and red light keeps blinking
In accordance with facility to watch The Wire online,you can go through entertaining .Watch Online The Wire Season 4 Episode6 - Watch-Series watch online series The Wire season 4 episode 6,download full episodes for freeWatch The Wire Online - Full Episodes ofThe Wire & More TV Set in Baltimore, this show centers around thecity's inner-city drug scene. It starts as ... the Wire - Watch Full Episodes of TV Shows Onlinecility to watch The Wire online with blinkx Remote
Jun 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
Bizzare problem with the color
Sounds like something may be wrong with your cable line might need to have it checked.
Aug 19, 2009 | Sony KV-32FS13 TV
SONY KV-20FV10 blinks off
Bad solder contacts on connector/component pins, oxydized connectors, dried up, inflated or blown electrolytic filter capacitors, burnt resistors.
Could be in the main or high voltage power supply, video section power supply, possibly in any of the other sections.
(these are just some ideas)
regards
3rq8 (Triarcuate)
Jul 27, 2009 | Sony KV-20FV10 20" TV
Sony tv picture blinks on and off
examine main board solder connections-preffeably with 10X magnifiers or is it just me lol--look for ring cracks in main power area and regulator chips,also flyback area-- good luck )
Jul 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Standby light blinking on sony trinatron no picture
resolder the crt circuit and also the video circuit,or find the trouble in the video circuit if there's an open resistor..
Jan 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
36 INCH 1997 - 1998 SONY TRINITON
Proceed with caution! High dangerous voltages exist within.
Check the current sense circuit from the aquadag coating.
Jul 15, 2017 | Televison & Video
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
277 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
