Question about Precor EFX 546i Elliptical Version 4
What is error 50 on the precor efx546 - Precor EFX 546i Elliptical Version 4
    President:
  • Precor Master
  • 832 Answers
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
Posted on May 14, 2010
How to fix error code 50 on EFX 5.21i?
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
May 22, 2014 | Precor Exercise & Fitness
Precor elliptical
3. Bad lower PCA.
Corrective Action
May 22, 2014 | Exercise & Fitness
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
422 code on EFX546 4H model, will not accept code to go into diagnostic mode
This link will take you to information on the diagnostics mode, beginning on page 8:
http://www.sportsmith.net/images/product_support%5Cprecor%5CService%20Manuals%5CCommercial%20EFX%5CService%20Manual,%20C546%20EFX.pdf
Jan 24, 2014 | Precor EFX 546i Elliptical Version 4
Precor brake error 50
3. Bad lower PCA.
Corrective Action
Nov 26, 2013 | Exercise & Fitness
Efx546 error 32
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Feb 19, 2012 | Precor EFX 546i Elliptical Version 4
I am looking for a parts and repair manual for a precor efx546 eliptical unit
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
Jul 27, 2010 | Precor EFX 546i Elliptical Version 4
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Error message "key depressed" and no resistance on elliptical.
you will need a keypad and overlay call National Gym Supply @ 1-800 496-7278 they will need M & S #
Feb 06, 2010 | Precor EFX 546i Elliptical Version 4
I have an Error message 50 coming up when iturn on my eliptical
3. Bad lower PCA.
Corrective Action
Jun 27, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
474 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
