Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP Officejet 7410
Hi!
I have the problem you refer to re the HP 7410 printer cartridge holder being broken. Where might I order a new one?
You may e-mail me at ukat101052@aol.com.
Thanks,
Jeff
  • Anonymous Apr 05, 2008
    Hi I broke off a little clip that holds the colored ink in tryed to glue it back in and still readfs error check ink cartridge. Do you have recomend a place to send it in and have it repaired? Thanks Malinda (malindasue31@yahoo.com)
  • m225v Aug 04, 2008
    black ink cartridge spring holder is broken.
    Problem Solver:
  • 10 Answers
When you find out Jeff, I sure need to know too! Here's my story:
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place.
Posted on Apr 23, 2008
I have an hp injet 5510 and I cannot remove the printer cartridge in order to replace the old with the new. Help! I have the door open with the printer on and cannot get it to come out.
You often have to tilt the cartridge to get it out. Some cartridges have plastic holders you have to disengage. Refer to your manual, or just inspect the cartridge holder carefully to figure out how to dislodge it.
Mar 13, 2010 | HP Officejet 5510 All-In-One Thermal...
My 7410 keeps saying to add a black ink cartridge but i did
Remove black cartridge and check to insure the spring has not broken loose.
Jan 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
RE 7410 COLOR cartridge problem
its a broken spring clip on the side of the ink cartridge.
fixes are here;
http://www.fixyourownprinter.com/forums/inkjet/46650#83
and here;
http://www.fixyourownprinter.com/forums/inkjet/50913#243
hp is supposed to give you a brand new printer for free.
Jan 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hi, I have HP 7410 printer. but I believe there is a hole in wires that connect to Black cartridge. Do you have that parts for sale?
It's really hard to get a broken wire inside the print mechanism, so I suspect that something else is going on. Have you tried using a different ink cartridge? If a different cartridge does the same thing examine the holder where the ink cartridge inserts, sometimes a little bit of debris (dirt, tape.etc) can get on the pins that connect the printer to the cartridge.
Carl
Dec 08, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer does not recognize color cartridge for my HP OfficeJet 7410
Are you sure it's a genuine HP cartridge? Sometimes remanufactured cartridges aren't recognized by the printers. HP and others make them so that they have a chip inside that ensures only new genuine cartridges can be used. Try a new HP and see if that solves the problem. If you've already tried that one, then make sure the contacts in the printer are clean. If you still have a problem, then I'd say try a new printer!
Oct 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp Office jet print cartridge error
Remove the cartridge and look at the cartridge holder. There should be a spring sticking out from the right side of the holder. The spring on these often breaks loose and will not allow the cartridge to seat properly. (Look at the left holder and compare it to the right one. They should look alike.) If the spring is loose, meaning the holder is broken, the holder needs to be replaced. I've tried gluing the spring in place but did not have good luck with this.
Feb 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ink cartridge carriage HP 7410
i would trace the line back and put a small wire to replace the broken path.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410
Sounds like a bad cartridge, you may want to try an original, it may be worth the cost instead of a new printer. First clean contacts on printer w/alcohool and put the cartridge back in. Not fixed try a new one may be worth the $40
Oct 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
